Substitution technique for integral
8 replies · 2K views
mathaintmybag
I need to use a substitution technique and then the table of integration to integrate the following:
∫ x5 √(x4 – 4) dx
and i am given a hint which is x5 = (x3)(x2)
I would assume that
u = x4 – 4, then du = 4x3
and that at some point a2 = 4 and a = 2
However, the x5 = (x3)(x2) is confusing the heck out of me. Need help!
What do a^2 and a have to do with anything?
The hint looks to me like it's guiding you to use integration by parts. Is that a technique that you have learned yet? I wouldn't advise it unless you have exhausted the possibilities for ordinary substitutions, however.
What, so you have a limited table of integrals that doesn't include this and you are suggested a substitution to give you a form you can find in your table?
I think the point of the x5 = x3x2 is to use the x3 as you have suggested with your u = x4 - 4. You can substitute for the extra x2 like this:
x4 = u+4, x2 = sqrt(u+4)
This will give you a pure u integral that may be in your table.
The reason i used a^2 = 4 and a = 2 is because in the book they used a number of different examples where they changed the number to a letter.
We have touched on integration by parts but everything we did learned involved using
ex so I am not really sure how to use it here.
It can be done with trig substitution I believe. Setting x^4/4 to (x^2/2)^2 and substituting for cos(theta).
∫ x5 √(x4 – 4) dx
∫ x5 2√(x4/4 – 1) dx
∫ x5 2√((x2/2)^2 – 1) dx
d/dx cosΘ = d/dx x^2/2]
[2cosΘ] = x^2]
[4cos^2(Θ)] = x^4]
-sinΘ dΘ = 2x dx∫ x5 2√((x2/2)^2 – 1) dx
∫ x^4(2x)√((x2/2)^2 – 1) dx
∫4cos^2(Θ) (-sinΘ)sinΘ dΘAnd then from there it's pretty simple... Is that right?
I haven't learned how to use trig substitutions yet so that will not help. Thanks for tip anyways.
x5√(x4 - 4) = x2∙x3√(x4 - 4)
and you can use integration by parts on that.
Would this be correct?
∫ x5 √(x4 – 4) dx
= ∫ ((x2*x2*x √(x4 – 4)) dx
Let u = x2, then du/2 = xdx
= ∫ 1/2 (u2√u2 – 4) du
Let a = 4 and a2 = 2
= ∫(u2√u2 – a2) du
= [x(u2 – a2)3/2 / 4] + [a2x√(u2 – a2) / 8] – (a4/8) ln(x + √(u2 – a2))
It looks like you are using formula #10 here.
If so, you final result should not have u or a in it. You also need the constant of integration, which is needed in all indefinite integrals.
