Suffix Notation Help: Nabla Vector Calculation
  • Thread starter Thread starter Matt atkinson
    Notation
9 replies · 2K views
Matt atkinson
Show that the equation [tex]\nabla \times \vec{p} = -\frac{\vec{B}}{r^3} + 3\frac{\vec{B} \bullet \vec{r}}{r^5}\vec{r}[/tex]
Where ;
[tex]\vec{p} = \frac{\vec{B} \times \vec{r}}{r^3}[/tex]
[tex]\vec{r}=(x_1 ,x_2 ,x_3)[/tex]
and [tex]\vec{B}[/tex] is a constant vector.
and r is the magnitude of [tex]\vec{r}[/tex]
above
[tex]\nabla \times \vec{p} = \epsilon_{ijk} \epsilon_{klm} \frac{d}{dx_j} B x_m |r|^{-3}[/tex]
[tex]= \epsilon_{ijk} \epsilon_{klj} B |r|^{-3} - 3 \epsilon_{ijk} \epsilon_{klm} B x_m x_j |r|^{-5}[/tex]
I've tried expanding and using various identities such as;
[tex]\epsilon_{ijk} \epsilon_{klm} = \delta_{il} \delta_{jm} - \delta_{im} \delta_{jl}[/tex]
If someone could give me a push in the right direction or let me know if i went wrong somewhere (i know i skipped a few steps but it took me 20 mins to right out the latex code for this adk if you don't see what I did).
Where ;
above
You're missing an [itex]l[/itex] suffix on the [itex]B[/itex] and the derivative is partial:
[tex] (\nabla \times \vec p)_i = \epsilon_{ijk} \epsilon_{klm} B_l \frac{\partial}{\partial x_j} \left(\frac{x_m}{r^3}\right)[/tex]
You will also need
[tex] \frac{\partial r}{\partial x_j} = \frac{x_j}{r}[/tex] and [tex] \frac{\partial x_m}{\partial x_j} = \delta_{jm}[/tex]
ah okay, hmm.
so I should use the product rule and get
[tex]\epsilon_{ijk} \epsilon_{klm} B_l x_m \frac{\partial r^{-3}}{\partial x_j} + r^{-3} \delta_{jm}[/tex]
I just don't see how to use [tex]\frac{\partial r}{\partial x_j}[/tex] maybe I'm being a little stupid.
Matt atkinson said:
ah okay, hmm.
You are missing some brackets: you should have
[tex] \epsilon_{ijk} \epsilon_{klm} B_l \left(x_m \frac{\partial r^{-3}}{\partial x_j} + r^{-3} \delta_{jm}\right)[/tex]
[tex] \frac{\partial}{\partial x_j} \left(\frac{1}{r^3}\right) = \frac{d (r^{-3})}{dr} \frac{\partial r}{\partial x_j}[/tex]
Thankyou so much, I've been trying to do this for a while now, can't believe it was chain rule i forgot
Okay, I am sorry i got stuck again, so i did the math and substitute the two epsilons for deltas uisng the identities i gave before, but i can't seem to cancel;
[tex]\delta_{il}\delta_{jj} B_jr^{-3} -\delta_{ij}\delta_{jl} B_jr^{-3} -3\delta_{il}\delta_{jm}B_j x_m x_j r^{-5}+3\delta_{im}\delta_{jl}B_j x_m x_j r^{-5}[/tex]
to the show that answer I am assuming the first and third term are zero? but I am not sure why, sorry about all the questions this suffix notation is very new to me.
Matt atkinson said:
Okay, I am sorry i got stuck again, so i did the math and substituent the two epsilons for deltas uisng the identities i gave before, but i can't seem to cancel;
The suffix on [itex]B[/itex] should be an [itex]l[/itex]; try again with
[tex] \delta_{il}\delta_{jj} B_l r^{-3} -\delta_{ij}\delta_{jl} B_l r^{-3} -3\delta_{il}\delta_{jm}B_l x_m x_j r^{-5}+3\delta_{im}\delta_{jl}B_l x_m x_j r^{-5}[/tex]
okay, I did that and got;
[tex]3B_i r^{-3} - B_i r^{-3} -3B_i x_j x_j r^{-5}+3B_j x_i x_j r^{-5}[/tex]
I just don't see how two of the terms cancel, not sure what I am missing
[itex]x_jx_j = r^2[/itex].
Wow thanks I feel kinda silly now.
Thanks so much for your help.
