Sum of a series from n=1 to infinity of n^2/(2+1/n)^n
The discussion revolves around the sum of the series from n=1 to infinity of n^2/(2+1/n)^n. Participants are exploring the convergence and potential methods to evaluate the series.
  • Mixed
  • Participants discuss rewriting the series in different forms and question the need for additional parentheses for clarity. There are inquiries about convergence tests and whether the goal is to find an exact or approximate value of the sum. Some suggest estimating the sum by adding terms.
There is an ongoing exploration of the problem with various approaches being suggested. Some participants are looking for similar examples in textbooks, while others are attempting to derive a function related to the series. The discussion reflects a mix of uncertainty and attempts to clarify the problem statement.
Participants note that they are required to find the sum of the series, which implies it must converge, although there is no consensus on the exact method to achieve this. There are mentions of using calculators for approximate values, but a formal method is still sought.
Frobenius21
Determine the sum of the series
Sum from n=1 to infinity of n^2/(2+1/n)^n
n^2/(2+1/n)^n
I tried to write it as n^2/2^n (1+1/2n)^n
But I am stuck there and don't know what to try next.Thanks for any help in advance!
Frobenius21 said:
Homework Statement:: Determine the sum of the series
Relevant Equations:: n^2/(2+1/n)^n
You need more parentheses. As you wrote it, it would be interpreted as ##\frac{n^2}{2^n}(1 + 1/2 \cdot n)^n##. What I think you meant was this:
##\frac{n^2}{2^n(1 + \frac 1 {2n})^n}##.
What tests do you know that you can use to test for convergence?
Thanks a lot, I am asked to find the sum of the series not to show if it converges.
How is possible to start with that?
If you're asked to show the sum of the series, then the series must necessarily be convergent.
Offhand, I don't have any ideas. Are there any similar examples in your textbook, or has your instructor shown you some similar examples in class?
A simple-minded way to find the sum of a series is to add a bunch of terms. If the series converges at a reasonable rate, you can get a pretty good estimate of the sum of the entire series. By adding up the first 25 terms (in Excel), I get a partial sum around 3.77.
Yes it should converge.
There are no similar examples that I know of. I am looking in textbooks to try to find something similar.
I'm tempted to regard this as [itex]f(1)[/itex] where
[tex]f(x) = \sum_{n=1}^\infty \frac{n^2}{(1 + \frac1{2n})^n}\left(\frac x2\right)^n[/tex]
Thanks
Can we have confirmation of what the question is - written out please.
Hi, I was just told to get the sum from n=1 to infinity of n^2/(2+1/n)^n
Does "get the sum" mean "get the exact value of the sum" or "get an approximate value of the sum"?
I don't have any ideas about how to get the exact value, but an approximate value is 3.77, as I described in post #4. @pasmith gave a hint earlier, but I don't see how that helps you get the exact value of the sum -- it's not a series that I recognize off the top of my head.
Thanks, I am just being ask to find a way to get the number of the sum
I also used a calculator to get the result it is 3.77381 but I am being ask to use a method to get to that result.
Not sure any of this will help, but I played with the function ##f(x):=\sum_{n=1}^{\infty}n^2\left( 1+\tfrac{1}{2n}\right) ^{-n}\left( \tfrac{x}{2}\right) ^n##. Note that ##f(x)## satisfies the integral equation
$$\int_{x_1=0}^{x}\int_{x_2=0}^{x_1}f(x_2 )\tfrac{dx_2 dx_1}{x_2 x_1}=\sum_{n=1}^{\infty}\left( 1+\tfrac{1}{2n}\right) ^{-n}\left( \tfrac{x}{2}\right) ^n$$
If somebody recognizes that sum on the right which *might* be a little nicer than the one we started with, "have integral equation, will travel..." Not sure where to go from here... we could also try a DE relation, but I'm stuck, I went in circles with the integral equation (proving something I already knew to start out with, oof!).
  • · Replies 17 ·
  • · Replies 24 ·
