Sum of angles with x,y and z axis made by a vector
The discussion centers on the relationship between the angles a vector makes with the x, y, and z axes in three-dimensional space, specifically questioning whether the sum of these angles (α, β, γ) equals 180 degrees. It is clarified that while in 2D, the angles α and β sum to 90 degrees, in 3D, the angles do not consistently sum to 180 degrees, as they can vary based on the vector's orientation. The angles are related through the equation cos²α + cos²β + cos²γ = 1, indicating a more complex relationship. Additionally, when a vector is rotated around one axis, the angles with the other axes change, further complicating the relationship. Ultimately, the angles can approach but do not always equal 180 degrees, highlighting the unique properties of three-dimensional geometry.
rakesh
sum of angles with x,y and z axis made by a vector
α + β + γ = 180°
I want to know if there is any proper relation between the angles of a vector with the three dimensional coordinate axes,
if the angles are ,α , β and γ,
will the sum of α, β and γ be 180 degress
that is α + β + γ = 180°,m finding the same to be true in a 2 D case where α + β = 90° and γ = , so the sum is 90°also will α + β
be always 90° as in 2D,
thanks.
A unit vector in spherical coordinates is written in the cartesian representation $$\mathbf{\hat r}=\sin\theta\cos\varphi ~\mathbf{\hat x}+\sin\theta\sin\varphi ~\mathbf{\hat y}+\cos\theta ~\mathbf{\hat z}$$The angles are defined as in the figure below. Do you know how to find the angle that an arbitrary vector makes with respect to the axes? If so, assume random numeric values for ##\theta## and ##\varphi##, calculate the angles this unit vector makes relative to the principal axes and see if they add up to 180°.
You might consider a vector that makes equal angles with the x, y, and z axes.
Likes Lnewqban and PeroK
have tried to rotate the vector and get angles instead of using an equation but did not get much, will appreciate if u can give a clear and direct answer, thanks.
i think each will be 60 degrees then but not sure.
Try to work it out. Can you write down a vector in unit vector notation that would make equal angles to the three axes?
my question is quite simple and i dnt want to enter into advanced approach of a unit vector and all.
α + β + γ = 180°
Yes
Simple have been the responses from @kuruman and @TSny
Your question seems a little confusing to me.
Lnewqban said:
α + β + γ = 180°
YesSimple have been the responses from @kuruman and @TSny
just see a 3d line and see the angles it makes with x, y and z axis, this is my question, is it confusing in any way.
Consider a cube with edges of length 1 and let ##\mathbf A## be the vector shown.
Can you use trig to determine the angle that ##\mathbf A## makes to the z-axis?
As you can see, it is perfectly possible for α + β + γ = 180°
Many combinations of those three angles can satisfy that equation.
For the particular case of each angle being 60 degrees, the projections of vector u on each plane x-y, y-z and x-z will make an angle of 45 degrees with both axes.
The simple answer is "no". The angles don't always add to 180 degrees.
Likes MatinSAR and Lnewqban
ok, so no relations between angles as we have seen in 2D, what about alpha plus bita, its also not equal to 90 ?
I thought you only wanted a simple answer?
Lnewqban said:
My concern is are these angles related in any way, m finding when they are equal the angles come to be cos inverse root 3 not 60 or 90 degrees.
Yes, as indirect answers will divert me from obvious vision and analysis on this simple case.
The key is that, using the inner product of unit vectors or otherwise we have:
$$\cos^2 X + \cos^2 Y + \cos^2 Z = 1$$Where ##X, Y, Z## are the angles between the vector and the coordinate axes. Note that if we take ##\cos Z = 0## to get the 2D case (x-y plane), then we can show that ##X + Y = \dfrac \pi 2## (or equivalent if we are outside the first quadrant).
Likes Lnewqban and MatinSAR
Yes. For example, ##\cos^2 \alpha +\cos^2 \beta + \cos^2 \gamma = 1##. [Edit: @PeroK already posted this.]
Yes. Good.
any maximum or minimum values of the sum of the angles.
Sounds like a calculus problem with a constraint.
Please, see excellent responses in posts #16 and #17 above.
Not only are the angles related, but the magnitude of the projection of the vector on each plane.
Retaking the case of 45 degrees projected over plane x-y:
Vector u will be projected at full length only if the vector is contained in plane x-y (γ = 90°).
Once the vector is tilting from that plane (γ < 90°, as shown in diagram of post #11), the length of its x-y projection becomes shorter and shorter until reaching a zero value when the vector becomes perpendicular to the x-y plane.
On the other hand, as long as the vector remains contained in plane x-y (γ = 90°), which is the 2-D particular case, its actual length will never change for any combination of α and β values (α + β = 90°).
if we will rotate the vector with a constant angle with x axis, will its angle with y axis go on changing ?
Lnewqban said:
α + β + γ = 180°
as mentioned by others, i concluded its not 180, its changing, at some point of time it becomes 180 by chance.
I am not sure that I fully understand your description.
If our vector shown in diagram of post #11 is made rotate around the x axis, keeping its tail at (0,0,0), it will describe the surface of a cone.
Lnewqban said:
α + β + γ = 180°
Yes
No.
… which cannot occur in Euclidean 3D space.
I'm confused by your responses. On the one hand you seem to say that the sum of the three angles will be 180°; on the other, you Liked post #12.
@rakesh/ @sachin (?), in N dimensions we have ##\Sigma_1^N\cos^2(\alpha_i)=1##.
For N=2, ##\cos^2(\alpha_1)+\cos^2(\alpha_2)=1##, which has the solution ##\alpha_1+\alpha_2=\pi/2##.
For a large number of dimensions, all of the angles can approach ##\pi/2## simultaneously, giving the approximation ##\Sigma_1^N(\pi/2-\alpha_i)^2=1##.
Yes, this is the exact case i meant, when alpha with x axis is kept constant, will beta be also constant
Yes, this is the exact case i meant, when alpha with x axis is kept constant, will beta be also constant ? moreover i dnt understand what is "angle measured with positive y axis" is it when measured in anticlockwise direction ?
I removed an off-topic post and replies to it.
Likes member 731016 and PeroK
Here's a contour plot for the value of ##\alpha+\beta+\gamma## as a function of the spherical coordinates ##\theta## and ##\phi## for the octant ##0 \leq \theta \leq 90^o## and ##0 \leq \phi \leq 90^o##. The numbers on the contours are the values of ##\alpha+\beta+\gamma##.
At any point on the square boundary of the plot, ##\alpha+\beta+\gamma = 180^o##. Everywhere else it is less than 180o. The minimum value of ##\alpha+\beta+\gamma## is approximately 164.2o and this occurs when the vector makes equal angles to the three axes: ##\cos \alpha = \cos \beta = \cos \gamma = \frac 1 {\sqrt 3}##; that is, when ##\theta = \cos^{-1}( \frac 1 {\sqrt 3}) \approx 54.7^o## and ##\phi = 45^o##.
Likes Lnewqban, haruspex, kuruman and 1 other person
