Sum of noncentral chi-square RVs
  • Context: Graduate
  • Thread starter Thread starter no999
    Sum
The sum of independent noncentral chi-square random variables (RVs) is itself a noncentral chi-square distribution. Specifically, when summing N independent and identically distributed (i.i.d.) noncentral chi-square RVs, their degrees of freedom and means are additive. The characteristic function approach can be utilized to analyze the distribution of the sum, where the product of individual characteristic functions represents the sum's distribution. For non-identical variances, the distribution may differ, necessitating further investigation into the F distribution for ratios of noncentral chi-square RVs.
  • Understanding of noncentral chi-square distribution
  • Familiarity with characteristic functions in probability theory
  • Knowledge of Gaussian random variables and their properties
  • Basic MATLAB programming for simulations
  • Research the properties of noncentral chi-square distributions in detail
  • Learn about characteristic functions and their applications in probability
  • Explore the F distribution and its relationship to noncentral chi-square distributions
  • Practice simulating noncentral chi-square distributions in MATLAB
Statisticians, data scientists, and researchers working with random variables, particularly those focusing on noncentral chi-square distributions and their applications in statistical modeling and simulations.
no999
Hi guys,
i amtrying to find the sum of N random variables each follow the noncentral chi-square distribution and they are i.i.d, i.e,
sum(y_i), i=1,...N
y_i is the RV and has a noncentral chi-square pdf
f[y](y) = (exp(-(H[i, d]+y)/sigma^2)*BesselJ(0, 2*sqrt(H[i, d]*y/sigma^4))/sigma^2
please help me
regards
nidhal
A sum of independent noncentral chi-square RVs is noncentral chi-square. You just add their degrees of freedom and means together. This follows directly from the definition (depending what definition you are using for chi-square, of course).
Hi, thanks for the info.
Actually, i cannot understand what do you mean by chi-square definition, my noncentral chi-square is a result of squared Gaussian RV with mean and segma^2.
i found an expression of the characteristic function of the noncentral chi-square but i am not sure if this expression is sufficient to represent the sums of the noncentral chi-square distribution, i am also not sure how to simulate this formula in MATLAB for example, can you help in that, or do you have any comment
Regards
The characteristic function approach will work: If X_1, X_2, \dots, X_n
are any independent rvs, then the characteristic function X_1 + X_2 + \dots + X_n equals the product of the individual characteristic functions: write an expression for the product of the c.v.s in your problem, note its form and what it tells you about the distribution of the corresponding sum.
I'm not sure what you mean by 'simulate in matlab'.
A sum of m independent unit variance squared Gaussian RVs added to a sum of n independent unit variance squared Gaussian RVs is clearly equal to a sum of (m+n) such squared Gaussians. So the sum of independent chi square RVs with degrees of freedom m and n respectively is a chi square with (m+n) degrees of freedom.
However, you seem to have an additional scaling factor sigma, in which case this will not hold if they have different sigmas.
thanks guys,
I found the analysis in one book, The Algebra of Random variables, M. D. Springer, university of Arkansas, it is a very old book but really good one one. now i am trying to find the ratio of two i.r.v each follow noncentral chi-square distribution
Any idea about that,
Regards
Nidhal
no999 said:
thanks guys,
Regards
Nidhal
Look up the F distribution. It may not be in older textbooks, but there are good descriptions on the web.
Hi Guys,
By definition, the sum of iid non-central chi-square RVs is non-central chi-square. what is the sum of ono-identical non-central chi-square RV.
I have a set of non zero mean complex Gaussian random variables H_i with a mean m_i and variance σ_i . i=1...N. H
the result of their square is non-central chi-square RM. Now what is the distribution of the sum of those non-central chi-square RV given that their variances are different "i.e., they are independent but non-identical distributed".
Kind Regards
