Summation Convention in Einstein Notation
7 replies · 2K views
olgerm
I got another basic question: should the summation in einstein notation start from first occurrence of index or in beginning of equation?
For eampledoes this equation ##R_{\alpha \beta }={R^{\rho }}_{\alpha \rho \beta }=\partial _{\rho }{\Gamma ^{\rho }}_{\beta\alpha }-\partial _{\beta }{\Gamma ^{\rho }}_{\rho \alpha }+{\Gamma ^{\rho }}_{\rho \lambda }{\Gamma ^{\lambda }}_{\beta \alpha }-{\Gamma ^{\rho }}_{\beta \lambda }{\Gamma ^{\lambda }}_{\rho \alpha }## from wikipedia mean:
## \sum_{j_1=0}^D(\sum_{j_2=0}^D(\frac{\partial{\Gamma ^{j_1}}_{\beta \alpha }}{\partial x^{j_1}}-\frac{{\Gamma^{j_1}}_{j_1 \alpha}}{\partial x^{\beta}}+{\Gamma^{j_1}}_{j_1 j_2}{\Gamma ^{j_2}}_{\beta \alpha }-{\Gamma ^{j_1}}_{\beta j_2 }{\Gamma^{j_2}}_{j_1 \alpha }))##
or
##\sum_{j_1=0}^D(\frac{\partial{\Gamma ^{j_1}}_{\beta \alpha }}{\partial x^{j_1}}-\frac{{\Gamma^{j_1}}_{j_1 \alpha}}{\partial x^{\beta}}+\sum_{j_2=0}^D({\Gamma^{j_1}}_{j_1 j_2}{\Gamma ^{j_2}}_{\beta \alpha }-{\Gamma ^{j_1}}_{\beta j_2 }{\Gamma^{j_2}}_{j_1 \alpha }))##?
Neither. Each individual term is summed by itself: ##A^iB_i+P^kQ_k## is to be read as##\sum_iA^iB_i+\sum_kP^kQ_k##
so it is same as last one beacuse ##\sum_i(A^iB_i)+\sum_k(P^kQ_k)=\sum_i(A^iB_i+P^iQ_i)##?
In this particular case, yes, that just happens to work. In more complex expressions you won't be able to combine terms under one summation the way you're trying to do. Consider, for example, ##A^iB_i+P^{ij}Q_{ij}## - the first term is a four-element summation and the second is a sixteen-element summation.
if every term has its own summation it is ##\sum_{i=0}^D(A^iB_i)+\sum_{i=0}^D(\sum_{j=0}^D(P^{ij}Q_{ij}))=\sum_{i=0}^D(A^iB_i+\sum_{j=0}^D(P^{ij}Q_{ij}))##?
Can you say clearly whether it is true that the equation ##R_{\alpha \beta }={R^{\rho }}_{\alpha \rho \beta }=\partial _{\rho }{\Gamma ^{\rho }}_{\beta\alpha }-\partial _{\beta }{\Gamma ^{\rho }}_{\rho \alpha }+{\Gamma ^{\rho }}_{\rho \lambda }{\Gamma ^{\lambda }}_{\beta \alpha }-{\Gamma ^{\rho }}_{\beta \lambda }{\Gamma ^{\lambda }}_{\rho \alpha }## from wikipedia means:
I can say clearly that it means$$R_{\alpha \beta }={R^{\rho }}_{\alpha \rho \beta }=\sum_\rho\partial _{\rho }{\Gamma ^{\rho }}_{\beta\alpha }-\sum_\rho\partial _{\beta }{\Gamma ^{\rho }}_{\rho \alpha }+\sum_{\rho,\lambda}{\Gamma ^{\rho }}_{\rho \lambda }{\Gamma ^{\lambda }}_{\beta \alpha }-\sum_{\lambda,\rho}{\Gamma ^{\rho }}_{\beta \lambda }{\Gamma ^{\lambda }}_{\rho \alpha }$$I haven't checked your algebra, but it is plausible that you've found a valid way of obscuring manipulating the formula.
Nugatory said:
obscuring
more easily readable for me. waiting foranswer whether it's correct or not.
  • Sad
If you insist on writing things differently from the way everybody else writes them, you can't expect everybody else to check your work. We have standard ways of writing things in physics for a reason.
Thread closed.
