Superposition of 3 point masses
The problem involves calculating the net gravitational force on sphere B due to two other spheres, A and C, with specified masses and distances. The context is gravitational interactions among point masses.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the application of gravitational force equations and the use of Pythagorean theorem for vector addition. There are questions about arithmetic accuracy and the completeness of the steps provided by the original poster.
Participants are engaged in verifying calculations and clarifying steps taken in the problem-solving process. There is an acknowledgment of discrepancies in results from different calculators, and some participants suggest re-evaluating the calculations for accuracy.
There is mention of potential limitations in calculator display affecting the precision of results. The original poster expresses uncertainty about the completeness of their steps, prompting further requests for clarification from others.
bravoman
In the figure below, three 2.00 kg spheres are located at distances d1 = 0.300 m and d2 = 0.400 m. What are the magnitude and direction of the net gravitational force on sphere B due to spheres A and C?
F = GMm/r^2
F=sqrt((4G/0.4^2)^2 + (4G/0.3^2)^2)
F = 3.0E-9
But that answer is wrong. Is there a mistake in my arithmetic? Of am i missing another term?
Yes. please post all steps.
F (B->C) = G(2)(2)/(0.4^2) = 4G/0.16
F (B->A) = G(2)(2)/(0.3^2) = 4G/0.09
F (B->net) = F(B->C) + F(B->A)
Can't add these together since they aren't the same direction, so use Pythagoras' theorem:
F^2 (B->net) = F^2(B->C) + F^2(B->A) = sqrt((4G/0.16)^2 + (4G/0.09)^2)
Yes, I understand you're doing that, but your result is inaccurate (not wildly wrong). I can't tell where the inaccuracy comes in unless you post all steps.
Just had a thought... is this what you meant to post, or have you left out a digit?
bravoman said:
3.0E-9
Im sorry, I don;t understand what you mean by "Post all steps", these are all the steps I have done. What more is there?
3.0E-9 is the result my calculator gives me, although the numbers may be cut-off since the calculator display is limited to 10 digits. I'll use an online calculator and see if it makes a difference
wolfram alpha gives 3.40125... × 10^-9 , so that might be the problem. Can you verify that the way I did the question is indeed correct?
Here are my steps (spreadsheet)
d1= 0.3
d2= 0.4
1/d1^4= 123.46
1/d2^4= 39.06
sum= 162.52
sqrt(sum)= 12.75
G= 6.67E-011
m*m= 4
*G*m*m= 3.40E-009
d1= 0.3
d2= 0.4
1/d1^4= 123.46
1/d2^4= 39.06
sum= 162.52
sqrt(sum)= 12.75
G= 6.67E-011
m*m= 4
*G*m*m= 3.40E-009
3.40125 × 10^-9 is indeed the correct answer! It was my calculator that ran out of displaying digits to properly show the number. Thank you for your time.
11K
  • · Replies 31 ·
