Superposition of the sound waves from two speakers
The discussion revolves around the superposition of sound waves emitted by two loudspeakers along the x-axis. The problem involves understanding the relationship between wavelength, phase difference, and amplitude as one speaker is moved relative to the other.
  • Participants discuss the calculation of wavelength and its implications for phase difference as one speaker is moved. Questions arise regarding how to measure phase differences when the speakers are at different positions, particularly when one speaker is moved in front of the other.
Participants are actively engaging with the problem, attempting to clarify the relationships between the variables involved. Some have provided calculations related to phase differences, while others express confusion about the formulas and concepts being discussed. There is a mix of understanding and uncertainty, with some participants seeking further clarification on specific terms and equations.
There are indications of varying levels of familiarity with the subject matter among participants, with some expressing that they are new to these types of physics problems. The discussion also highlights the need for clear definitions of variables and terms used in the equations.
Elsi b
Two loudspeakers emit sound waves of the same frequency along the x -axis. The amplitude of each wave is a. The sound intensity is minimum when speaker 2 is 10 cm behind speaker 1. The intensity increases as speaker 2 is moved forward and first reaches maximum, with amplitude 2a, when it is 30 cm in front of speaker 1. What is
a. The wavelength of the sound?
b.The phase difference between the two loudspeakers?
c.The amplitude of the sound (as a multiple of a ) if the speakers are placed side by side?
Wavelength=2L
2pix/wavelength+Phasedifference
Wavelength = 2L = 80cm
Elsi b said:
Homework Statement:: Two loudspeakers emit sound waves of the same frequency along the x -axis. The amplitude of each wave is a. The sound intensity is minimum when speaker 2 is 10 cm behind speaker 1. The intensity increases as speaker 2 is moved forward and first reaches maximum, with amplitude 2a, when it is 30 cm in front of speaker 1. What is
Relevant Equations:: Wavelength=2L
I confirm your value for wavelength.
The rest I cannot make sense of and it is truncated. Please define your variables and post as typed algebra, preferably in latex. Images are for diagrams and textbook extracts.
One symbol is unclear... could be a lowercase x or a backward α.
ϕ=2πx/λ for the phase difference, how can you measure the phase difference for the speaker 2 when it moves to its maximum? I was trying to measure the speaker 2 at its minimum and then measure it to its maximum... does it make sense ...thanx
Yes, that is a general formula for converting a distance movement to a phase shift.
With speaker 2 30cm in front, a listener hears them as in phase.
If you move speaker 2 back from its 30cm in front position to be next to speaker 1, what phase difference does that make for the listener?
It will be destructive waves when speaker 2 moves before to be in phase constructive with speaker 1
I don’t think you understood my question, and I certainly don’t understand your answer.
You have calculated the wavelength.
Suppose there is a listener somewhere in front of the speakers and speaker 2 is 30cm in front of speaker 1. The listener hears them as in phase.
Now speaker 2 is moved to be at the same place as speaker 1. How much further is that from the listener? Using the formula in post #3, what phase change does that make to what the listener hears from speaker 2?
I know The two sounds waves will add up, but the formula ϕ=2πx/λ
I have no idea what you mean by "but the formula ϕ=2πx/λ". It is not a sentence.
Please try to answer my questions in post #6.
Ill try to reply to ur question and this is what i understood. Let's take speaker 2 and the length is 30cm. How far is the wave (from speaker 2) can reach to the listener? This is what i understood... or maybe if u can explain to me? Thanx :-I
No, I'm not asking how far the wave has to travel to reach the listener. I did not specify exactly where the listener is.
Let me try a different tack.
Take a snapshot of the wave emitted from speaker 1. Draw a diagram. You have a sine curve that comes from speaker 1 out past speaker 2, 30cm in front. The snapshot is at an arbitrary instant, so it could be at any phase at speaker 1. It will be at a different phase at speaker 2
If it is at phase Φ1 at speaker 1, what phase is it at speaker 2?
Is English a second language for you? If so, please try using something like Google translate for both my questions and your answers.
Phase 2 speaker 2
Elsi b said:
Phase 2 speaker 2
The answer I am looking for to my question in post #10 is an expression involving Φ1, λ and 30cm. It uses the relevant equation you provided in post #1.
Hey friend: i think u are a little bit advance in the formula. I am still new in this kind of questions. The formula that u posted , this one Φ1 its the first time is see this. What does it mean? Thanx. And if u know how to solve this question, i really appreciate it. Now I am starting to do complicated physics problems. Thanx for the help
You posted this relevant equation:
Do you understand what it means?
If speaker 1 is emitting a sine wave ##A\sin(\omega t)## then at time t1 the phase at the speaker is ##\omega t_1##.
Its angular frequency is ##\omega## radians per second and its cycles per second frequency is ##\frac{\omega}{2\pi}##
If the wave moves at speed v then it has wavelength λ where ##v=\frac{\lambda\omega}{2\pi}##. It advances a distance one wavelength each cycle.
A part of the wave emitted at time t0 will take time x/v to travel distance x.
So at time t1 at a distance x from the speaker the phase will be ##\omega (t_1-\frac xv)=\omega (t_1-\frac{2\pi x}{\lambda\omega})=\omega t_1-\frac {2\pi x}{\lambda}##.
Meanwhile, speaker 1 is at phase ##\omega t_1##, so what is the phase difference between speaker 1's position and distance x from it?
If you conclude the time for example, The phase difference at t1 is Pi rad.
No.
At time t1, speaker 1 is emitting at phase
haruspex said:
##\omega t_1##
Whereas at distance x in front of speaker 1, at the same instant, the wave from speaker 1 is at phase
haruspex said:
##\omega t_1-\frac {2\pi x}{\lambda}##.
So what is the difference between those two?
haruspex said:
No.
ok the difference between the two formula is the difference -2πx/λ
Right, so if x is 30cm and the wavelength is what you calculated, what is the phase difference in radians?
2πx/λ
=2π0.3/0.8
=2.355
=π/1.33 rad :rolleyes:
correct me if I am wrong before the speaker 2 moves to the front, can i measure the Δθ?
2πx/λ
=2π0.1/0.2
whats makes it hard is that speaker 2 moves in the front of speaker 1...
ok so this is what i came up with
2πx/λ
=2π0.3/0.8
=3/4π
2πx/λ
=2π0.3/0.8
=3/4π
Yes.
haruspex said:
Yes.
Thanx for the help
Elsi b said:
Thanx for the help
You are welcome, but do you now understand it? I worry that I maybe gave too much help in post #14.
yes the difference between two phases when the wave in phase moves to another position,
  • · Replies 19 ·
