Superposition principle applied to a linear circuit
19 replies · 6K views · last reply
Gabry89
I have to find I3, I've already easily found the first component I3| but i don't understand how i can get I3||.
I thought about a Wheatstone bridge but doesn't work looking at the data.
The result is I3=-7 A
You drew the two sources the same way, but you're treating them differently. Is one a voltage source and the other a current source?
Your analysis of the second case is completely wrong. R1 and R2 aren't in series, nor are R3 and R4.
actually they're not draw in the same way and yes they're a voltage and a current source.
Then i don't understand how to get the second component cause I've tried again the exercise and I've found the correct result thinkin' about R1 and R2 in parallel and the same for R3 and R4.
I've forgotten to say that after having found I3 i must find also the power generated by E and the same for J
Moderator's note: thread moved to "Engineering, Comp Sci, & Technology".
Please use the Engineering, Comp Sci, & Technology forum for electronics problems.
You found the correct result by thinking about R1//R2 and R3//R4, that's because they are indeed in parallel!
What are you confused about?
The symbols you're using aren't typical for either current or voltage sources. See, for instance, http://en.wikipedia.org/wiki/Voltage_source.
What you're saying here doesn't match what you posted originally, nor does it contradict what I said earlier, which was, again, based on what you posted originally. It does sound like you did end up figuring the problem out correctly, though.
i've studied that when I'm trying to get Req i don't have to consider the presence of the sources as they would have been switched off. According to this consideration here's why they're in series.
Thank you very much, here's a better place.
is that correct now?
well, i know that these symbols are the most common in this case but other equivalent symbols are those i drew. E.g. here's a pic I've found in wikipedia http://commons.wikimedia.org/wiki/F...c_symbols_of_current_source.png?uselang=en-gb
well, i know that these symbols are the most common in this kind case but other equivalent symbols are those i drew. E.g. here's a pic I've found in wikipedia http://commons.wikimedia.org/wiki/F...c_symbols_of_current_source.png?uselang=en-gb
-5A is what I get for the second case as well.
Then it should be right.
Now i have to find the power of the current source and the same for the voltage source.
I've found that:
I1 = I1| + I1|| = 2 A
I2 = I2| + I2|| = 14 A
I3 = I3| + I3|| = 9 A
I4 = I4| + I4|| = 7 A
Pe+PJ= I12R1 + I22R2 + I32R3 + I42R4 + E2/R5
But how i get them separately?
I've found that:
If you want to find the power the current source is supplying, simply take the voltage across the current sources times the current the source is supplying the circuit with.
Same with the voltage source, figure out what current the source is supplying the circuit with and multiply it by the voltage.
Regardless of whether the source is present or not, R1 and R2 are not in series; same with R3 and R4.
then how would you get the Req? and why if i consider them in series for calculating Req the result is correct?
Talking about PJand PE i tried doing like this:
PJ = J*Vab = 819.2 W
PE= E*IE = E2 / Req = 320
which are not the correct results. The correct results are: PJ= 1392 W, PE = 288 W
In your calculations, you multiply by Req to find VAB and then later divide by it to find I3, so it ends up canceling out.
You used
[tex]V_{AB} = R_{\mathrm{eq}} J[/tex]
followed by
[tex]V_{R_3R_4} = V_{AB} \left(\frac{R_3 || R_4}{R_{\mathrm{eq}}}\right) = R_{\mathrm{eq}} J \left(\frac{R_3 || R_4}{R_{\mathrm{eq}}}\right) = J(R_3 || R_4)[/tex]
You could have used any value of Req and gotten the correct answer. Note that your final answer turns out to be
[tex]I_3 = \frac{R_4}{R_3+R_4} J[/tex]
Do you recognize that formula?
For two elements to be in series, all the current that goes through one element must go through the other. That's certainly not true for the pair R1 and R2 nor for the pair R3, which carries 7 A, and R4, which, by KCL, must carry 9 A.
In series, elements are connected end-to-end with nothing else connected the nodes. With R1 and R2, they're connected both on the left and right ends. Since both nodes have other circuit elements connected to them, R1 and R2 are not in series.
On another note, you have R5 in parallel with a short circuit when you remove the voltage source. What's the equivalent resistance of that combination?
Sure, it's the current divider, i thought about that but i was confused by the short circuit in the middle, well thanks now it's clear.
Well, when a resistor is in parallel with a short circuit the voltage across the resistor is 0 then the equivalent resistance of that combination is 0.
Right. I wasn't sure if you realized that because in your first attempt, you kept R5 and got rid of the short, and in your subsequent attempt, you still included R5 even though you could remove it.
Also, since you asked earlier about how to find Req when E=0, I thought I'd mention that in your second attempt, you reduced the circuit to the point where you should be able to see what the equivalent resistance is between A and B.
too bad i don't find the correct answer, i tried it again with my colleagues but I've found
PJ = 1360 W rather than PJ = 1392 W which is the correct answer.
I've found that:
Didn't you say I3=-7 A was the correct answer earlier? Why are you using 9 A now?
It's not really informative if you just say you got the wrong answer. How did you calculate the power? In particular, how did you find the voltage across the current source?
Note that you can't use superposition when finding the power since power isn't linear. You need the voltage and current through the sources in the original circuit.
Sorry i wrote it wrong in the post, i wrote I3 instead of I4 and viceversa
The correct currents are:
I3 = I3| + I3|| = 7 A
I4 = I4| + I4|| = 9 A
yes, sorry, here's what i mean
Req = (R1 || R2) + (R3 || R4) = 5,3125 [tex]\Omega[/tex]
PJ = J2 * Req = 1360 W
To calculate the power correctly, you need to find the currents and voltages in the original circuit. You can't calculate the powers individually with the other source set to 0, which is what you are effectively doing by using Req.
Why? Consider the current source, for example. The voltage across it will change depending on whether you have E=0 or E=32 V, but in both cases, it will source 16 A of current. Since P=IV, the power provided will be different between the two cases.
done! I've found out how to manage that problem:
(KCL) IE| = IR2| + IR4| + IR5| =10 A
(KCL) IE|| = IR1| - IR3|| = 1 A
PJ = J2*Req + (I3|*R3 - I1|*R1) * J = 1392 W
PE = E*IE| - IE||*E
