Symmetric matrix with eigenvalues
5 replies · 2K views
Ylle
Let {u1, u2,...,un} be an orthonormal basis for Rn and let A be a linear combination of the rank 1 matrices u1u1T, u2u2T,...,ununT. If
A = c1u1u1T + c2u2u2T + ... + cnununT
show that A is a symmetric matrix with eigenvalues c1, c2,..., cn and that ui is an eigenvector belonging to ci for each i.
No clue...
I'm really stuck with this problem. So I'm really just hoping for a little hint or something.
It SOUNDS easy, but as I said, I have no clue where to start.
Hope you can help.
Regards
Hi Ylle! :smile:
Ylle said:
… show that A is a symmetric matrix with eigenvalues c1, c2,..., cn and that ui is an eigenvector belonging to ci for each i.
(i assume you can prove that A is symmetric)
You just need to prove that Aui = ciui
(and remember the basis is orthonormal :wink:)
Hi :)
I'm not totally sure about the first, but I have this (See the picture added). I don't know if it is proved there ?
For it to be symmetric it's it has to be: A = AT, right ?
And the next I can't figure out what you mean :?
If you add ui to A I guess you can remove the u1-n and u1-nT because they become the identitymatrix for all of them. And then you have c1-nui left. So how do I make the c1-n to ci ? :)
Hi Ylle! :smile:
Yes, A = AT.
But your proof doesn't work, because transpose is like inverse … it alters the order of things … so (AB)T = BTAT :wink:
Just write Aui in full (using the orthonormality of the u's) …
what do you get? :smile:
Well, my guess is you have:
A = ciuiuiT
If you then add ui on both sides you get:
Aui = ciuiuiTui
And because uiuiT = <ui,<ui> = ||ui|| = 1 since it's a basis, you have:
Aui = ciui
Don't know if that is correct ?
Hi Ylle! :smile:
(btw, please don't say "add" :eek: … say "multiply", or if you prefer a more neutral word, "apply" :wink:)
Ylle said:
… And because uiuiT = <ui,<ui> = ||ui|| = 1 since it's a basis, you have:
Aui = ciui
Yup, that's fine …
that's what "orthonormal" is all about! :biggrin:
but … you still have to deal with all the u's in the ∑ that aren't that particular ui
use the orthonormal property again. :smile:
