Symmetry in a Triangular Circuit
  • Thread starter Thread starter bananabandana
    Circuit Symmetry
The discussion revolves around finding the resistance across points A and B in a triangular circuit, utilizing symmetry to analyze current distribution. The context involves understanding the relationship between geometric symmetry and current division in electrical circuits, particularly in the framework of a Wheatstone bridge.
  • Participants explore the concept of symmetry in circuits, questioning how it influences current flow at junctions. There are inquiries about the conditions under which currents can be considered equal and the implications of a balanced Wheatstone bridge. Some participants express confusion about the necessity of zero current through certain paths and seek clarification on the relationship between symmetry and potential differences.
The discussion is active, with participants sharing insights about the Wheatstone bridge and its implications for current flow. There is a mix of understanding and uncertainty, particularly regarding the concept of balance in the circuit and its effect on current distribution. Guidance has been offered regarding the conditions for zero current, but no consensus has been reached on the underlying principles of symmetry.
Some participants mention the complexity of applying Kirchhoff's laws to the problem, indicating potential constraints in the information provided or assumptions being made about the circuit's configuration.
bananabandana
Find the resistance across AB. Use symmetry to determine currents.
Please see diagram.
I really don't seem to understand symmetry in circuits. What is the link between the geometrical symmetry of the situation and the way in which the current divides at a junction? Is it the case that if a current can follow two possible paths, and the paths have the same resistances in the same order, that the current along each path is equal??
In the diagram below for example, why is I6 supposed to be zero? How do I know that points D and A are at the same potential? I've tried expanding everything using Kirchoff's laws, but it just becomes very messy...
Thanks!
do you know a term something called as "weigh stone bridge" ??
Um, I think you mean 'Wheatstone bridge'. Yes, I do know that the example I've got is a balanced Wheatstone bridge, but I'd still like to better understand how symmetry works in circuits in general.
at here if
R1/R2=R3/R4
then there will be no current through the R6 i.e I6=0
Yes, but why? How does the symmetry of the problem relate to this understanding? :P
all the subs scripts represents the resistance of your question i.e
R1 is the resistance from where I1 current will flow and so on...
Yes, I understand that! What I don't understand is why it is necessary, that, in this example, a balanced Wheatstone bridge must have no current flowing through the middle wire.. if that's not a stupid question :P
If a bridge is balanced, then the 2 outside voltage dividers give equal voltages at each end of the middle resistor.
  • · Replies 31 ·
