Symplectic but Not Complex Manifolds.
Every complex manifold can be equipped with a symplectic structure using the form w:=dz/dz^, though this is only locally defined and may lose closedness when patched globally. The Hopf surface S^1 x S^3 serves as an example of a complex manifold that lacks a symplectic structure due to its cohomology properties. It is suggested that not all symplectic manifolds can be given a complex structure, with references to examples like a circle bundle over a circle bundle over the 2-torus. Gompf's work in the 1980s introduced non-Kähler symplectic manifolds that do not conform to the Hodge decomposition. The discussion highlights the complexities in the relationship between symplectic and complex structures.
Bacle2
Hi, All:
AFAIK, every complex manifold can be given a symplectic structure, by using
w:=dz/\dz^ , where dz^ is the conjugate of dz, i.e., this form is closed,
and symplectic. Still, I think the opposite is not true, i.e., not every symplectic
manifold can be given a complex structure. Does anyone know of examples/results?
I heard something about an equivalence between Lefschetz fibrations (or pencils)
and existence of symplectic structures, but I cannot think of examples.
Any Ideas?
Bacle2 said:
Hi, All:
and symplectic.
But this form is defined only locally. And trying to patch it globally, you may lose closedness. In her (free, available on her website) book, Ana Cana da Silva mentions the Hopf surface S^1 x S^3 as a complex manifold that does not admit a symplectic structure (obviously since H^2(S^1 x S^3) = 0 x H^2(S^3)=0.) See p.122.
For this Silva gives a reference for an example of Ferdandez-Gotay-Gray that is a circle bundle over a circle bundle over the 2-torus. (p.121)
Bacle, I think you mean to say that every Kahler manifold can be given a symplectic structure. That the converse is not true is much more delicate. Gompf discovered non-Kahler symplectic manifolds in the 80's, using some surgery construction to produce symplectic manifolds that do not satisfy the Hodge decomposition on cohomology.
Thanks, both for your comments, refs., I will look into them.
