System of differential equations question
4 replies · 2K views
bitrex
I have to solve the following system of differential equations, given some initial conditions:
[tex]mx'' = qBy'[/tex]
[tex]my'' = -qBx'[/tex]
Rearranging I get [tex]x'' - \frac{qB}{m}y' = 0[/tex]
[tex]y'' + \frac{-qB}{m}x' = 0[/tex]
Computing the operational determinant I get [tex]cD^3 + cD^3[/tex], where C = qB/m. Continuing I apply the operators to x and y to get [tex]2cD^3x = 0[/tex] and [tex]2cD^3y = 0[/tex]. So basically I get [tex]y''' = 0[/tex] and [tex]x''' = 0[/tex]. I'm not sure how this helps me solve the system of differential equations, as with the characteristic equation r^3 = 0 if one root is 0 then the others could be anything...I think I've gone wrong somewhere but cannot see it. Any help would be appreciated.
Differentiating the first equation gives:
mx''' = qBy'' and from the second equation y'' = -(qB/m)x'. Substitute that in for y'':
mx''' = -(q2B2/m)x'
x''' + c2x' = 0 where c =(q2B2/m2)
Let w = x' and you have a second order constant coefficient equation in w = x'.
If I continue in that way, I find that [tex]x' = C_1 + C_2e^{-Ct}[/tex] and [tex]y' = C_3 + C_4e^{-Ct}[/tex], so x is equal to [tex]C_1t - \frac{C_2}{C}e^{-Ct} + C_3[/tex] and y is equal to [tex]C_4t - \frac{C_5}{C}e^{-Ct} + C_6[/tex]. C is equal to [tex]\frac{q^2B^2}{m^2}.[/tex]
I now have 6 constants, but I should really only have 2...I also have 4 initial conditions from the problem, namely [tex]x_0 = r_0, y(0) = 0, x'(0) = 0, y'(0) = -\omega r_0[/tex] where omega = qB/m. Do I plug the solutions for x and y back into the original equations and start equating coefficients and hope that I'll be left with only 2 constants? My goal is to show that the particle moves in a circle with radius [tex]r_0[/tex] but I don't see it yet. Thanks so much for your help!
how do you get [itex]x' = C_1 + C_2e^{-ct}[/itex] from [itex]x''' + c^2x' = 0[/itex]?
differentiating
[tex]x' = C_1 + C_2e^{-ct}[/tex]
[tex]x'' = -c.C_2e^{-ct}[/tex]
[tex]x''' = c^2 C_2e^{-ct}[/tex]
substituting back into the original equation gives
[tex]x''' + c^2x' = c^2 C_2e^{-ct} + c^2(C_1 + C_2e^{-ct}) \neq 0[/tex]
follow LCKurtz suggestion let w = x' and solve
[itex]w'' + c^2w = 0[/itex]
I see it now. I made a mistake setting up my characteristic equation..:redface:
