System of Linear Equations to Resolve Room Dimensions
The problem involves determining the dimensions of a room based on the arrangement of ceiling panels and a perimeter strip. The context includes a grid of panels and a total length for the edge/middle strip that runs around and between them.
  • Participants discuss translating the problem details into a solvable system of linear equations. There are attempts to express relationships between the width and length of the panels, as well as the total length of the strip.
Some participants have made attempts to formulate equations based on the given information, while others are questioning the interpretation of the strip's placement and its impact on the calculations. There is a mix of proposed equations and ongoing exploration of the problem setup.
Participants note potential confusion regarding the placement of the strip and its relation to the dimensions of the panels. There is also mention of the need for clarity in the assumptions made about the dimensions and arrangement of the panels.
kyle1984
Twelve equal rectangular ceiling panels are placed in a four long by three wide grid. Each panel is 150mm longer than it is wide. Between the panels runs an edge/middle strip which totals 40.0m in total length. (This runs round the whole perimeter and between each panel). By developing a system of linear equations what are the dimensions of the room?
So I have been staring at this all day. I know I am missing something simple but translating the given detail into something I can develop and solve is just a block at the moment. I would love some guidance if possible.
Have made many but none are correct!
The phrase "The attempt at a solution" does NOT refer only to successfu ones. If you have made many attempts, you should be able to show one[b\]. Seeing your mistakes will help us know what hints will help you.
Ok well the best I have come up with so far is 4(4w+0.6)+5(3w)=40
Where w = width
Actually I think I have it now.
where w = width and l = length.
1. w=l-0.15
2. 16l+15w=40
Substituting into Eq 2
16l+15(l-0.15)=40
16l+15l-2.25=40
l=1.36m
Therefore:
w=1.36-0.15=1.21m
So overall room dimensions are 3w=3.63m and 4l=5.44m
That seems to work out and follow fairly sensible logic I think.
So the strip runs between the tiles? I think you must calculate half the sum of the length of any side that touches another tile. Set this to 40 and you'll be able to find the solution.
  • · Replies 69 ·
11K
  • · Replies 21 ·
  • · Replies 17 ·
