High School Can a Gravitational System be Treated as a Single Curved Spacetime?
  • Thread starter Thread starter BeedS
    Spacetime System
The discussion centers on whether a gravitational system, such as the Earth and Moon, can be treated as a single curved spacetime. At large distances, the combined gravitational field can be approximated as that of a point mass located at the system's barycenter. However, for practical applications like rocket travel between objects, this approximation fails due to the complexities involved. The conversation also touches on atomic systems, noting that atoms are not gravitationally bound and that their gravitational fields are too weak to measure accurately. Ultimately, while systems can appear as point sources at sufficient distances, the definition of "far enough" is contingent on the precision of measurements.
BeedS
Hey, if I take two objects for Example the Earth and Moon and treat them as a gravitational bound “system”. The Earth and Moon have their own local curves in spacetime. Can I use/treat the whole “system” as a curve in spacetime? For example, a curve that includes all objects of the “system” mass/gravity merged/added and is strongest at the “systems” Barycenter.
Depends what for. At a large enough distance the field will be pretty much identical to the field of a point mass at the barycentre, although that mass may or may not be well approximated by the sum of the independent masses (it would be ok for Earth and Moon). So in that case, yes you could. If you want to fly rockets from one object to the other, no, not even close.
If I take objects for Example the particles of an atomic system and treat them as a gravitational bound “system”… ? ...is the atomic system far enough? :oops:
Yes, I was thinking for external objects located outside the system, interacting with the system.
You mean the gravitational field of a single atom? It's too tiny for is to know if GR models it correctly. Assuming it does, though, you'd need such incredibly precise measurements to detect the field that it's impossible to say how close you could go and still treat it as a point source.
Note that an atom is not gravitationally bound. Atoms are held together by strong forces in the nucleus and electromagnetic forces between the nucleus and electrons.
Basically, any system will look like a point source when you're far enough from it. But what "far enough" means in practice depends on how precisely you're measuring. For a simple example, consider the case of the Sun, mass ##M_S## and distance ##R## away from you, and the Earth, mass ##M_E## and distance ##R+r## away from you. We'll have you, the Earth and the Sun in a straight line so we can be lazy about vectors and use Newtonian gravity, because that's valid way before pretending the Earth and Sun are a single point is valid.
The gravitational acceleration you feel is $$\begin{eqnarray*}
g&=&\frac{GM_S}R+\frac{GM_E}{R+r}\\
&=&\frac{GM_S}R+\frac{GM_E}{R}\frac{1}{1+r/R}\\
&=&\frac{GM_S}R+\frac{GM_E}{R}\left(1-\frac{r}{R}+\frac{r^2}{R^2}-\frac{r^3}{R^3}+\ldots\right)\\
&=&\frac{G(M_S+M_E)}R-\frac{GM_E}{R}\left(\frac{r}{R}-\frac{r^2}{R^2}+\frac{r^3}{R^3}-\ldots\right)
\end{eqnarray*}$$Whether you can detect the difference between that and ##G(M_S+M_E)/R^2## depends on whether the experiment you are doing is far enough away that your measurement error is bigger than that last term in the brackets - that is that your distance from the Sun, ##R##, is so much larger than the Earth-Sun distance, ##r##, that all those terms in the brackets are so nearly zero you don't care.
Likes BeedS and PeroK
It's too tiny to tell if Newtonian gravity models it correctly too.
Likes Nugatory, Ibix and PeroK
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 21 ·
