Taking the gradient of 1/r (solid sherical harmonics?)
  • Context: Graduate
  • Thread starter Thread starter hanson
    Gradient Harmonics
The discussion focuses on calculating the gradient and Laplacian of the function 1/r in spherical coordinates. The gradient is established as ∇(1/r) = -1/r² * i_r, while the Laplacian is derived as ∇²(1/r) = 0, confirming that the second derivative results in zero due to the nature of the radial function. Participants clarify the distinction between the Laplacian and dyadic products, with the latter yielding a tensorial form. The final tensor representation is expressed as (3/r³) * i_r * i_r - (I/r³), where I is the identity matrix.
  • Spherical coordinates and their notation
  • Vector calculus, specifically gradient and Laplacian operators
  • Tensor calculus and dyadic products
  • Understanding of scalar functions and their derivatives
  • Study the derivation of the Laplacian in spherical coordinates using the divergence theorem
  • Explore tensor calculus applications in physics, particularly in electromagnetism
  • Learn about the properties and applications of solid spherical harmonics
  • Investigate the implications of dyadic products in vector calculus
Students and professionals in mathematics, physics, and engineering, particularly those working with vector calculus and spherical harmonics.
hanson
Hi all, just an very elementary question, arising from the first study of generating harmonic solutions.
How to get the gradient twice for
<br /> 1/r <br /> in spherical coordinates?
Hi hanson! :smile:
What's the difficulty?
1/r obviously doesn't depend on θ or φ, so just use ∂/∂r. :wink:
tiny-tim said:
Hi hanson! :smile:
Hello. Yea,
I think I can get the gradient of 1/r once, using the ∂/∂r, and that will gives me a vector.
What confuses me is taking it another time, which will gives me a tensor. However, the answer I got is different from what is supposed to be.
tiny-tim said:
Hi hanson! :smile:
This is SO wrong!
Let us do this properly (sort of!):
First:
\nabla\frac{1}{r}=-\frac{1}{r^{2}}\vec{i}_{r}
Now, \nabla^{2}\frac{1}{r}=(\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{\theta}\frac{1}{r\sin\phi}\frac{\partial}{\partial\theta}+\vec{i}_{\phi}\frac{\partial}{r\partial\phi})\cdot(-\frac{1}{r^{2}}\vec{i}_{r})
Now, you are to apply each of these operators PRIOR to perform the dot products!
Since the vector \vec{i}_{r}[/tex] depends upon both the angular variables, differentiating that vector will yield components PARALLELL to the direction of the angular variable.<br /> Thus, non-zero contributions to the full Laplacian of 1/r will appear from these differentiations.
Okay, I'm generous today, so we use the identities:
\frac{\partial\vec{i}_{r}}{\partial\phi}=\vec{i}_{\phi}
\frac{\partial\vec{i}_{r}}{\partial\theta}=\sin\phi\vec{i}_{\theta}
Thus, we get:
\nabla^{2}\frac{1}{r}=\frac{2}{r^{3}}-\frac{1}{r^{3}}-\frac{1}{r^{3}}=0
As you should get.
In general, when dealing with a function f(r), where r is the radial vector in spherical coordinates, we have the simple relation:
\nabla^{2}f=\frac{1}{r^{2}}\frac{d}{dr}(r^{2}\frac{df}{dr})
arildno said:
This is SO wrong!
First:
<br /> <br /> Hi, arildno. Thanks for the detail reply.<br /> But what if it is not a dot product between \nabla and \nabla \frac{1}{r}? If it is a dot product, then we will get a Laplacian. However, if it is like a &quot;dyadic product&quot; (I am not sure if this is the right term to use, but seems to be), then we should get a tensor out of this, right? And the result should be something like \frac{\vec{\vec{I}}}{r^3} + 3 \frac{\vec{r}\vec{r}}{r^5}, where \vec{r} = r\vec{i}_{r} and \vec{\vec{I}} is the identity matrix. I am not sure how to get this. I kind of got the second term, but not the first one. Could you please help?<br /> <br /> p.s. I am sorry about the missing &quot;arrows&quot; above the identity matrix and the &quot;r&quot;s. They cannot display properly, since I am not familiar with latex typing here...
OKay, I was a bit unsure if it was the Laplacian or the dyadic tensor you were after; it is, however, fairly trivial to set up in this case (remember that the Laplacian is the sum of the diagonal terms)!
You get the tensor:
f^{,,}\vec{i}_{r}\vec{i}_{r}+\frac{f^{,}}{r}\vec{i}_{\theta}\vec{i}_{\theta}+\frac{f^{,}}{r}\vec{i}_{\phi}\vec{i}_{\phi}
Note that this is rewritable as:
\frac{3}{r^{3}}\vec{i}_{r}\vec{i}_{r}-\frac{I}{r^{3}}=\frac{3}{r^{5}}\vec{r}\vec{r}-\frac{I}{r^{3}}
You get the tensor:
Oh...the "f' here refers to a general function? So, you get this formula basically by performing similar steps below, right?
I have done this is the most boring and lengthy way
In spherical coordinates,
<br /> \nabla = \vec{i}_r \frac{\partial}{\partial r}+ \vec{i}_{\phi} \frac{1}{r} \frac{\partial}{\partial \phi}+\vec{i}_\theta \frac{1}{r sin \phi} \frac{\partial}{\partial \theta}<br />
So,
<br /> \nabla \left(\frac{1}{r}\right) = \vec{i}_r \frac{-1}{r^2} <br />
which is
<br /> \nabla(\nabla(\frac{1}{r})) = \vec{i}_r \vec{i}_r \frac{2}{r^3} + \vec{i}_\phi \vec{i}_\phi \frac{-1}{r^3}+\vec{i}_\theta \vec{i}_\theta \frac{-1}{r^3}<br />
And, it is rewritten as
<br /> \vec{i}_r \vec{i}_r \frac{3}{r^3} +\vec{i}_r \vec{i}_r \frac{-1}{r^3} + \vec{i}_\phi \vec{i}_\phi \frac{-1}{r^3}+\vec{i}_\theta \vec{i}_\theta \frac{-1}{r^3},<br />
which is
<br /> \vec{i}_r \vec{i}_r \frac{3}{r^3} - \frac{\vec{\vec{I}}}{r^3}<br />
p.s. I edited this 100 times but the latex still doesn't show up properly...i want to give up...
But the above steps are basically correct, right?
YEs, f was a general scalar function, only dependent upon the radial variable.
What you have done above is correct, and you Latex seems just fine.
If you want a similar tensorial form for a general f, you might rewrite post 8 as:
r\frac{d}{dr}(\frac{f^{,}}{r})\vec{i}_{r}\vec{i}_{r}+\frac{f^{,}}{r}I
where I is, again, the identity matrix.
Thanks arildno!
divergence theorem
You can also find ∇2 of a spherically symmetric f(r) using the divergence theorem
V2f(r)dV = ∫S f(r).dS = ∫S df/dr er.dS
So if V is the volume between two concentric spheres of radius r and r + dr (so that S is the surface of the two spheres, and er.dS = ±dS),
then 4πr22f(r) dr = d/dr(4πr2 df/dr) dr,
so ∇2f(r) = (1/r2) d/dr(r2 df/dr) :wink:
