Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## Why?
  • Thread starter Thread starter ElectronicTeaCup
    Means Tan
The discussion centers on the equation Tan ##2 \theta=4 /(1-1)##, which leads to the conclusion that ##2 \theta=90^{\circ}##, resulting in ##\theta=45^{\circ}##. Participants clarify that as ##\theta \rightarrow \frac{\pi}{2}##, ##\tan \theta \rightarrow +\infty##, and they explore the implications of undefined expressions in trigonometric contexts. The conversation also touches on the ambiguity of the expression ##1-1## and its impact on the analysis of limits and vertical tangents in trigonometric functions.
  • Understanding of trigonometric identities, specifically Tan and Cot functions.
  • Familiarity with limits and undefined expressions in calculus.
  • Knowledge of parameterization in polar coordinates.
  • Basic algebraic manipulation involving fractions and equations.
  • Study the behavior of trigonometric functions near their asymptotes, focusing on Tan and Cot.
  • Learn about limits in calculus, particularly how they apply to undefined expressions.
  • Explore the concept of vertical tangents in parametric equations.
  • Investigate the derivation and implications of the double angle formula for tangent: ##\tan 2x = \frac{2 \tan x}{1 - \tan^2 x}##.
Mathematics students, educators, and anyone interested in advanced trigonometry and calculus concepts, particularly those dealing with limits and undefined expressions in trigonometric functions.
ElectronicTeaCup
Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## and ##\theta=45^{\circ}##
None
One of my solutions had this in one part. Why is this the case?
For what values of ##\alpha## does ##\tan{\alpha}## diverge to positive infinity?
ElectronicTeaCup said:
Homework Statement:: Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## and ##\theta=45^{\circ}##
Relevant Equations:: None
You know that as ##\theta \rightarrow \frac \pi 2## then ##\tan \theta \rightarrow +\infty##?
Oh right, I wasn't even thinking about infinity, I was just thinking of it as "undefined"
Also, is this also correct?##\begin{array}{l}
\cot 2 \theta=0 \\
\frac{\cos 2 \theta}{\sin 2 \theta}=0 \\
\cos 2 \theta=0 \\
2 \theta=90
\end{array}##
\cot 2 \theta=0 \\
\cos 2 \theta=0 \\
2 \theta=90
\end{array}##
That's right where ##2\theta## is between ##0## and ##180°##. Another solution could be ##2\theta = 270°##.
Isn't ##1-1## a bit ambiguous, though? Was this a limit like ##x-1##?
A related example... if we parameterise a circle with ##(x,y) = (a\cos{\theta}, a\sin{\theta})## s.t. ##y' = -\frac{\cos{\theta}}{\sin{\theta}}## and wanted to see where the circle is vertical, would you also take issue with identifying ##\sin{\theta} = 0 \implies \theta = 0, \pi##?
1 - 1 = 0, which is not at all ambiguous. However, the fraction ##\frac 4 {1 - 1}## is undefined.
No problem with identifying the vertical part, but ##y'## either goes to infinity or negative infinity depending on how you choose to make ##\theta## go to either of those values (right or left of ##0## or ##\pi##).
The same thing with the ##1/(1-1)## fraction. Whether you have it ##1-x## or ##x-1##, then, however ##x## approaches ##1##, you will get different results (##\pi/2## or ##-\pi/2##).
@Mark44 this is what I was aiming at.
I see your point, and I the interpretation would be clearer from context.
In most cases where I've seen these sorts of steps, it hasn't mattered from which side you approach ##x## (e.g. for my circle example, a gradient of ##\infty## is equivalent to one of ##-\infty## for purposes of determining the vertical tangent).
A hand-wavy algebraic solution:
$$\tan 2x = \frac{2 \tan x}{1-\tan^2 x} = \frac{4}{0} \rightarrow 0 = 4-4\tan^2 x \rightarrow \tan^2 x = 1$$
And from here the ##\frac{\pi}{4}## falls out "neatly", along with all the other solutions. But be careful, this is "illegal" math. However, you started off with a statement of ##\frac{4}{0}##, I feel okay using hand-wavy tactics here.
Is that really the problem as given to you? I suggest that you had done some work to arrive at that. If so, please post the actual problem.
I seem not to understand this problem, well what i know is that,
##tan 2x## = ##\dfrac {2 tan x}{1-tan ^2 x}## and given that (from OP)##tan 2θ## = ##\dfrac {4}{1-1}## if indeed ##2tan x=4## then ##⇒tan x=2## which clearly contradicts with ##tan^2 x=1##.
With 0 in the denominator the problem is not well defined so there is no point wasting your time trying to understand it, move on.
