Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## Why?
  • Thread starter Thread starter ElectronicTeaCup
    Means Tan
The discussion revolves around the equation Tan ##2 \theta=4 /(1-1)##, leading to the interpretation that ##2 \theta=90^{\circ}##. Participants are exploring the implications of this equation and the behavior of the tangent function near undefined points.
  • Some participants question the validity of the expression ##1-1## and its implications for the tangent function. Others explore the concept of divergence to infinity and the conditions under which tangent becomes undefined. There are discussions about the relationship between tangent and cotangent, as well as the interpretation of limits in the context of the problem.
The discussion is active, with participants raising various interpretations and clarifications regarding the original problem. Some have offered insights into the behavior of tangent and cotangent functions, while others express confusion about the problem's setup and its implications.
There are concerns about the ambiguity of the expression ##1-1## and its role in the problem. Participants note that the presence of zero in the denominator renders the problem ill-defined, prompting discussions about how to approach such situations in mathematical contexts.
ElectronicTeaCup
Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## and ##\theta=45^{\circ}##
None
One of my solutions had this in one part. Why is this the case?
For what values of ##\alpha## does ##\tan{\alpha}## diverge to positive infinity?
ElectronicTeaCup said:
Homework Statement:: Tan ##2 \theta=4 /(1-1)##. This means ##2 \theta=90^{\circ}## and ##\theta=45^{\circ}##
Relevant Equations:: None
You know that as ##\theta \rightarrow \frac \pi 2## then ##\tan \theta \rightarrow +\infty##?
Oh right, I wasn't even thinking about infinity, I was just thinking of it as "undefined"
Also, is this also correct?##\begin{array}{l}
\cot 2 \theta=0 \\
\frac{\cos 2 \theta}{\sin 2 \theta}=0 \\
\cos 2 \theta=0 \\
2 \theta=90
\end{array}##
\cot 2 \theta=0 \\
\cos 2 \theta=0 \\
2 \theta=90
\end{array}##
That's right where ##2\theta## is between ##0## and ##180°##. Another solution could be ##2\theta = 270°##.
Isn't ##1-1## a bit ambiguous, though? Was this a limit like ##x-1##?
A related example... if we parameterise a circle with ##(x,y) = (a\cos{\theta}, a\sin{\theta})## s.t. ##y' = -\frac{\cos{\theta}}{\sin{\theta}}## and wanted to see where the circle is vertical, would you also take issue with identifying ##\sin{\theta} = 0 \implies \theta = 0, \pi##?
1 - 1 = 0, which is not at all ambiguous. However, the fraction ##\frac 4 {1 - 1}## is undefined.
No problem with identifying the vertical part, but ##y'## either goes to infinity or negative infinity depending on how you choose to make ##\theta## go to either of those values (right or left of ##0## or ##\pi##).
The same thing with the ##1/(1-1)## fraction. Whether you have it ##1-x## or ##x-1##, then, however ##x## approaches ##1##, you will get different results (##\pi/2## or ##-\pi/2##).
@Mark44 this is what I was aiming at.
I see your point, and I the interpretation would be clearer from context.
In most cases where I've seen these sorts of steps, it hasn't mattered from which side you approach ##x## (e.g. for my circle example, a gradient of ##\infty## is equivalent to one of ##-\infty## for purposes of determining the vertical tangent).
A hand-wavy algebraic solution:
$$\tan 2x = \frac{2 \tan x}{1-\tan^2 x} = \frac{4}{0} \rightarrow 0 = 4-4\tan^2 x \rightarrow \tan^2 x = 1$$
And from here the ##\frac{\pi}{4}## falls out "neatly", along with all the other solutions. But be careful, this is "illegal" math. However, you started off with a statement of ##\frac{4}{0}##, I feel okay using hand-wavy tactics here.
Is that really the problem as given to you? I suggest that you had done some work to arrive at that. If so, please post the actual problem.
I seem not to understand this problem, well what i know is that,
##tan 2x## = ##\dfrac {2 tan x}{1-tan ^2 x}## and given that (from OP)##tan 2θ## = ##\dfrac {4}{1-1}## if indeed ##2tan x=4## then ##⇒tan x=2## which clearly contradicts with ##tan^2 x=1##.
With 0 in the denominator the problem is not well defined so there is no point wasting your time trying to understand it, move on.
