Solve tan^2a=tanbtanc: Prove and Simplify
  • Thread starter Thread starter shravan
The discussion revolves around proving and simplifying the equation tan^2a = tanb tan c, starting from the relationship sin(a+b)/sin(a+c) = [sin(2b)/sin(2c)]^(1/2). Participants are exploring trigonometric identities and relationships between angles.
  • Participants discuss manipulating the initial equality and question the assumptions regarding the angles a, b, and c. Some suggest squaring terms and factoring, while others express uncertainty about the relationships between the angles.
The discussion is ongoing, with various approaches being suggested. Some participants have indicated that they have made progress by squaring terms, while others are questioning the validity of the initial assumptions and the completeness of the information provided.
There is a suggestion to assume that a + b + c = 180 degrees, but this assumption is questioned by participants. The completeness of the problem setup is also under scrutiny, with some indicating that additional information may be necessary to proceed effectively.
shravan
sin(a+b)/sin(a+c)=[ sin(2b)/sin(2c)]^(1/2)
then prove tan^2a=tanbtanc
I have reached till {tan(a)cos(b)+ sin(b)} * {sin(c)cos(c)}^(1/2)=
{tan(a)cos(c)+sin(c)}* { sin(b) cos(b)}^(1/2)
Can you assume that a+b+c = 180 degrees ?
I think there is something missing in your question. How elese can you prove the first equality ?
Or is it given ? In that case, you can find a connection between the angles by manipulating this first equality.
marlon
you have all the info you need. i squared everything, and then solved for tan^2a. its messy, but it does work out. when you square it all, the tana terms cancel. and then you just have to factor and divide ect.
no there is no relation between the angles.the relation given is not going to help much. I think I will be getting a method for that sum.however thank u
it works out. i said that already. just keep trucking. like i said, square everything and start gathering terms. its just a lot of math, but it does work.
try using some of these identities
Tan=cos/sin
Sin(a+b)=
SinaCosb+CosaSinb
Cos(a+b)
CosaCosb-SinaSinb
ya that's my knowledge of trig
the OP already used those identities. the only other identy needed is knowing tanx= sinx/cosx. otherwise its all just rearranging the equation.
  • · Replies 18 ·
