Tarzan/vine physics problem on work/energy/power
  • Thread starter Thread starter brnnpink4
    Physics
The problem involves Tarzan swinging across a valley on a vine, with specific parameters including the length of the vine, his mass, and the angle of the vine with the vertical. The questions focus on determining his speed at the lowest point of the swing and the tension in the vine at that moment.
  • Participants discuss the conservation of energy as a method to analyze the problem, questioning how to identify the energy gained and lost during the swing. There is also mention of uniform circular motion in relation to the tension in the vine.
The discussion is active, with participants exploring the relationship between kinetic and potential energy. Some guidance has been offered regarding the conservation of energy, and there is an acknowledgment of the need to consider changes in energy rather than absolute values.
Participants are navigating the assumptions related to energy conservation and the initial conditions of the problem, such as Tarzan starting from rest.
brnnpink4
Tarzan swings across a valley on a vine. The vine is 6m in length. Tarzan has a mass of 85kg. The angle that the vine makes with the vertical in his initial position is 15 degrees. What is his speed at the bottom of the wing? What is the tension of the vine at this point?
All help is appreciated!:)
f=ma
p=mvcosx
PE-mgh
KE=.5mv^3
KE+PE+W=KEf+PEf
KE=.5(85)v^2
PE=85(9.8)h
Try conserving energy for part one: what energy is gained, and what energy is lost?
For the second part, it's an example of uniform circular motion, and you can make use of this equation:
[itex]a = \frac{v^{2}}{r}[/itex]
How would you figure out what energy is gained/lost??
Just think about the situation: he starts from rest, and then starts swinging: that's kinetic energy gained. If energy is gained in the system, then that means that somewhere else energy is lost. That's in the potential energy lost when he loses elevation from where he starts to the bottom of the swing.
So would you set kinetic energy and potential energy equal to each other and solve for v?
Essentially, but remember that since the energies are changing, you need to find the changes in each of the energies, i.e. final - initial. Then sum those changes and set the result equal to zero (meaning energy is conserved).
Ok I think I got it! Thank You!
10K
