Taylor expansion in radial coordinates
The discussion centers on proving that the discrete Laplacian operator in radial coordinates, specifically the expression for the grid function u_{l,m} at the central point (l=0, m=0), is a second-order accurate approximation of the continuous Laplacian. The operator is defined as \(\delta_{\Delta\circ}u_{0,0}=\frac{4}{N_{\theta}h_{r}^{2}} \sum_{m=0}^{N_{\theta}-1} \left(u_{1,m}-u_{0,0}\right)\). Participants explore Taylor expansions of the grid function u_{1,m} and identify errors in their calculations, particularly in the handling of mixed partial derivatives. The correct formulation of the mixed derivative operator is crucial for achieving the desired accuracy.
  • Understanding of Taylor series expansions in multiple variables
  • Familiarity with the discrete Laplacian operator in numerical analysis
  • Knowledge of partial derivatives and their applications in physics
  • Basic concepts of radial coordinates and grid functions
  • Study the derivation of the continuous Laplacian in polar coordinates
  • Learn about the properties of mixed partial derivatives and their implications
  • Explore numerical methods for approximating differential operators
  • Investigate the application of Taylor expansions in numerical simulations
Students and researchers in applied mathematics, physics, and engineering who are working on numerical methods for solving partial differential equations, particularly in radial coordinates.
MJD3366
This shouldn't be so hard to do I guess, but I just cannot figure it out. The problem statement:
Prove that the special form of the discrete Laplacian operator in radial coordinates acting on a grid function u_{l,m} at the central grid point l=0, m=0, given by:
\displaystyle\delta_{\Delta\circ}u_{0,0}=\frac{4}{N_{\theta}h_{r}^{2}} \sum_{m=0}^{N_{\theta}-1} \left(u_{1,m}-u_{0,0}\right)
is a second-order accurate approximation to the continuous Laplacian. In order to do this, consider the values of the grid function u_{1,m} to be values of a continuous function at the location x=h_{r}\cos mh_{\theta}, y=h_{r}\sin mh_{\theta} and perform Taylor expansions about the point x=0, y=0. To be clear: h_{r} and h_{\theta} denote the radial and angular grid spacings respectively.
\displaystyle u_{1,m} = u\left(x,y\right) = u\left(h_{r}\cos mh_{\theta}, h_{r}\sin mh_{\theta}\right)
\displaystyle u\left(x,y\right) = u\left(0,0\right) + x \frac{\partial u}{\partial x} + y \frac{\partial u}{\partial y} + \frac{1}{2!} \left(x^{2}\frac{\partial^{2}u}{\partial x^{2}} + 2xy \frac{\partial^{2}u}{\partial x\partial y} + y^{2}\frac{\partial^{2}u}{\partial y^{2}}\right) + \dots
\displaystyle \frac{\partial u}{\partial x} = \cos mh_{\theta} \frac{\partial u}{\partial h_{r}} - \frac{\sin mh_{\theta}}{h_{r}} \frac{\partial u}{\partial mh_{\theta}}
\displaystyle \frac{\partial u}{\partial y} = \sin mh_{\theta} \frac{\partial u}{\partial h_{r}} + \frac{\cos\displaystyle mh_{\theta}}{h_{r}} \frac{\partial u}{\partial mh_{\theta}}
\displaystyle \frac{\partial^{2}u}{\partial x^{2}} = \cos^{2}mh_{\theta} \frac{\partial^{2}u}{\partial h_{r}^{2}} - \frac{2\sin mh_{\theta}\cos mh_{\theta}}{h_{r}} \frac{\partial^{2}u}{\partial h_{r}\partial mh_{\theta}} + \frac{\sin^{2}mh_{\theta}}{h_{r}^{2}} \frac{\partial^{2}u}{\partial \left(mh_{\theta}\right)^{2}} + \frac{\sin^{2}mh_{\theta}}{h_{r}} \frac{\partial u}{\partial h_{r}} + \frac{2\sin mh_{\theta}\cos mh_{\theta}}{h_{r}^{2}} \frac{\partial u}{\partial mh_{\theta}}
\displaystyle \frac{\partial^{2}u}{\partial y^{2}} = \sin^{2}mh_{\theta} \frac{\partial^{2}u}{\partial h_{r}^{2}} + \frac{2\sin mh_{\theta}\cos mh_{\theta}}{h_{r}} \frac{\partial^{2}u}{\partial h_{r}\partial mh_{\theta}} + \frac{\cos^{2}mh_{\theta}}{h_{r}^{2}} \frac{\partial^{2}u}{\partial \left(mh_{\theta}\right)^{2}} + \frac{\cos^{2}mh_{\theta}}{h_{r}} \frac{\partial u}{\partial h_{r}} - \frac{2\sin mh_{\theta}\cos mh_{\theta}}{h_{r}^{2}} \frac{\partial u}{\partial mh_{\theta}}
\displaystyle \frac{\partial^{2}u}{\partial x\partial y} = \sin mh_{\theta}\cos mh_{\theta} \frac{\partial^{2}u}{\partial h_{r}^{2}} + \frac{1}{h_{r}} \left(\cos^{2}mh_{\theta} - \sin^{2}mh_{\theta}\right) \frac{\partial^{2}u}{\partial h_{r}\partial h_{\theta}} - \frac{\sin mh_{\theta}\cos mh_{\theta}}{h_{r}^{2}} \frac{\partial^{2}u}{\partial mh_{\theta}}
\displaystyle \Delta u=\frac{\partial^{2}u}{\partial r^{2}} + \frac{1}{r^{2}} \frac{\partial^{2}u}{\partial\theta^{2}} + \frac{1}{r} \frac{\partial u}{\partial r}
From what I can make up from the problem statement, I thought the way to go to solve this problem is just to substitute for the cartesian operators and variables in terms of the radial ones up to second-order in the expansion of u_{1,m} and then by cancellation I would be left with something which resembles the continuous Laplacian in radial coordinates. However, when I do this I get the following result:
\displaystyle u_{1,m} = u\left(h_{r}\cos mh_{\theta},h_{r}\sin mh_{\theta}\right) = u\left(0,0\right) + h_{r} \frac{\partial u}{\partial h_{r}} + \frac{1}{2!}\left[h_{r}^{2} \frac{\partial^{2}u}{\partial h_{r}^{2}} + 2h_{r}\sin^{2}mh_{\theta}\cos^{2}mh_{\theta} \frac{\partial u}{\partial h_{r}} + 2\sin mh_{\theta}\cos mh_{\theta}\left(\cos^{2}mh_{\theta} - \sin^{2}mh_{\theta}\right) \frac{\partial u}{\partial mh_{\theta}}\right]
This substitution is kind of tedious, so I have carried it out twice now in order to avoid any mistakes, but this is the result I get. The first term naturally cancels with the term u_{0,0} from the definition and the linear term seems to be correct (shouldn't this cancel, since it shoulde be second-order accurate?). However, the second-order terms do not really fit in for some reason. The first second-order term looks sort of right (except for a factor of 2 that is), but the other two second-order terms don't make much sense. Maybe I am going about this in completely the wrong way, but I do not really no what do differently really...
If someone could help me out with this, I would be very grateful.
Is there nobody who can help me out with this? Maybe the problem statement is not clear enough? (although this is exactly how it is stated in the original text).
I'm currently trying my hand it this guy, but you might consider also posting this on the advanced physics part of the homework subform. These are the kind of manipulations physicists eventually become quite adept at doing.
EDIT: [STRIKE]Alright, I got it. Try substituting your expressions for \frac{\partial^2u}{\partial x^2} and \frac{\partial^2u}{\partial y^2} into the rectangular Laplacian.[/STRIKE]
EDIT: I take that back. oops.
Wow, how embarrassing...
I made a huge mistake regarding the operator \frac{\partial^2}{\partial x\partial y}. In my haste I assumed you could just multiply the operators \frac{\partial}{\partial x} and \frac{\partial}{\partial y}, but this obviously is not true. It's correct expression is:
\displaystyle \frac{\partial^2}{\partial x\partial y} = \sin mh_{\theta}\cos mh_{\theta} \frac{\partial^2}{\partial h_r^2} + \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r^2} \frac{\partial}{\partial mh_{\theta}} - \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r} \frac{\partial^2}{\partial h_r\partial mh_{\theta}} + \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r^2} \frac{\partial}{\partial mh_{\theta}} - \frac{\sin mh_{\theta}\cos mh_{\theta}}{h_r^2} \frac{\partial^2}{\partial mh_{\theta}^2}
Haven't yet got around to trying this out, but surely this is why I did not end up with the right answer to the original problem.
[STRIKE]
\displaystyle \frac{\partial^2}{\partial x\partial y} = \sin mh_{\theta}\cos mh_{\theta} \frac{\partial^2}{\partial h_r^2} + \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r^2} \frac{\partial}{\partial mh_{\theta}} - \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r} \frac{\partial^2}{\partial h_r\partial mh_{\theta}} + \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r^2} \frac{\partial}{\partial mh_{\theta}} - \frac{\sin mh_{\theta}\cos mh_{\theta}}{h_r^2} \frac{\partial^2}{\partial mh_{\theta}^2}[/itexHaven't yet got around to trying this out, but surely this is why I did not end up with the right answer to the original problem.
][/STRIKE]<br /> <br /> <br /> This isn&#039;t right, I made some errors again. It really should be:<br /> <br /> \displaystyle \frac{\partial^2}{\partial x\partial y} = \sin mh_{\theta}\cos mh_{\theta} \frac{\partial^2}{\partial h_r^2} - \frac{\sin mh_\theta\cos mh_\theta}{h_r} \frac{\partial}{\partial h_r} - \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r} \frac{\partial^2}{\partial h_r\partial mh_{\theta}} + \frac{\sin^2mh_{\theta} - \cos^2mh_{\theta}}{h_r^2} \frac{\partial}{\partial mh_{\theta}} - \frac{\sin mh_{\theta}\cos mh_{\theta}}{h_r^2} \frac{\partial^2}{\partial mh_{\theta}^2}
