Taylor/Maclaurin series for piecewise defined function
The discussion revolves around the Taylor/Maclaurin series expansion of a piecewise defined function, specifically examining the function's behavior at the point of transition between its two definitions. Participants explore the implications of continuity, differentiability, and the uniqueness of power series representations in relation to the function's parameters.
  • One participant presents a piecewise function and attempts to derive its Maclaurin series, noting that the expansion appears to only represent one part of the function.
  • Another participant asserts that the expansion around s=0 is limited to the behavior of the function in that vicinity and may not represent the function accurately elsewhere.
  • A participant acknowledges the non-analytic nature of the function at the transition point and expresses interest in the existence of a power series representation when the parameters differ.
  • It is suggested that the power series will converge only in the region where it is defined, not across the entire domain of the piecewise function.
  • A participant questions how to prove that a power series cannot converge to the entire function for all s > 0.
  • Another participant states that a power series converging to one exponential function must also converge to that function outside the defined interval, implying uniqueness.
Participants express differing views on the convergence of the power series and its ability to represent the piecewise function across its entire domain. There is no consensus on the existence of a power series that accurately describes the function for all values of s.
Participants note the limitations of the expansion due to the piecewise nature of the function and the potential lack of differentiability at the transition point. The discussion highlights the dependence on the parameters a and b, as well as the implications for the radius of convergence.
cg78ithaca
Consider the function:
$$F(s) =\begin{cases} A \exp(-as) &\text{ if }0\le s\le s_c \text{ and}\\
B \exp(-bs) &\text{ if } s>s_c
\end{cases}$$
The parameter s_c is chosen such that the function is continuous on [0,Inf).
I'm trying to come up with a (unique, not piecewise) Maclaurin series expansion for it:
F(s)=F\left(0\right)+\sum_{n=1,2..}\frac{F^n(0)}{n!}s^n=A+\sum_{n=1,2..}\frac{F^n(0)}{n!}s^n
And since for 0 < s < s_c:
F^n(s)=A\frac{d^n}{ds^n}\exp{\left(-as\right)}=-aA\frac{d^{n-1}}{ds^{n-1}}\exp{\left(-as\right)}=…={\left(-a\right)}^nA\exp{\left(-as\right)}
so
F^n\left(0\right)={\left(-a\right)}^nA
it follows:
F\left(s\right)=A\left(1+\sum_{n=1,2..}\frac{{\left(-a\right)}^n}{n!}s^n\right)
which is clearly the expansion of A exp(-as), not of F(s) -- I never used the
second part of the definition involving B exp(-bs).
Can anyone explain what the problem is here? I suspect it has to do with evaluating high-order derivatives in a neighborhood of s = +0, which should be influenced by the shape of F(s) for s>s_c as the derivation order increases, but not sure how to handle that mathematically.
The expansion around s=0 depends on the function around s=0 only. You cannot expect it to describe your function everywhere - even without piecewise definitions it does not have to converge to the function everywhere.
If ##a \neq b##, your function does not even have a first derivative at sc.
Thanks Mfb. Indeed I am aware of the existence of non-analytic functions, and regarding your point that F(s) is not differentiable at s_c, it is well-taken, but I am doing the expansion around s = 0 where it is infinitely differentiable. Regarding your other point which touches on the topic of radius of convergence, I guess I'm generally interested to know if F(s) for a<>b can be expressed as a power series as described above (existence) and if so, how I would go about determining the expansion coefficients in this case.
The power series won't converge to your function in both regions, no matter where you make the expansion. It will converge to it in the region where you make it, but not in the other.
Thanks Mfb. How do you prove that statement, namely that a power series that converges to F(s) for the whole s > 0 does not in fact exist?
The power series that converges to one exponential function over any finite interval is unique. It has to converge to that exponential function outside as well. It cannot converge to other things.
Thanks Mfb. That makes sense.
