Teardrop loop-de-loop radius function
  • Thread starter Thread starter nagyn
    Function Radius
1 reply · 3K views · last reply
nagyn
To avoid this stress, vertical loops are teardrop-shaped rather than circular, designed so that the centripetal acceleration is constant all around the loop. How must the radius of curvature R change as the car's height h above the ground increases in order to have this constant centripetal acceleration? Express your answer as a function: R=R(h).
Given variables:
Initial radius R0
Initial velocity v0
a_c = v2/r
v = r*ω
ΔPE = -ΔKErotational -ΔKEtranslational
ΔPE = mgh
-ΔKEtranslational = (1/2)m(v02 - vf2)
-ΔKErotational = (1/2)m(r02ω02 - rf2ωf2)
if v=r*ω, then unless I'm mistaken, ΔKErotational = ΔKEtranslational (substitution), and therefore:
mgh = m(v02 - vf2)
Mass cancels out. Since centripetal acceleration is constant, I know that a_c initial = a_c final, therefore:
vf2 = (v02*rf)/r0
Substituting this back into the energy equation and then doing algebra,
rf = r0((v02 - gh)/v02)
This is incorrect, and I can't figure out where I've gone wrong?
You are doing a really "weird" mistake, you consider the same energy two times. The car has rotational kinetic energy which in this case is the "same" as its translational kinetic energy. When I say "same" I mean its the same thing (and not two different things but equal). So in your equation of energy you should keep the factor of 1/2, that is ##mgh=\frac{1}{2}m(v_0^2-v_f^2)##.
The rotational kinetic energy is "different thing" and not equal to the translational kinetic energy in the case we have a wheel that is rolling with translational velocity ##v## and has rotational velocity ##\omega## around its center and the additional equation ##v=\omega R## holds (that is the condition of rolling without sliding, R the radius of wheel). In this case the total kinetic energy of the wheel is ##\frac{1}{2}I\omega^2+\frac{1}{2}mv^2## where I the moment of inertia of the wheel.
