Technique to detect thin metal film break?
  • Context: Graduate
  • Thread starter Thread starter ummux
    Break Film Metal
The discussion revolves around techniques for detecting pinholes or openings in a thin metal film, specifically in the context of a scored stainless steel disc used in pipelines. Participants explore various methods for real-time detection of failures, including electrical resistance changes, micromagnetic methods, and eddy current testing.
  • Experimental/applied
  • Some participants propose using electrical resistance measurements to detect changes when the disc ruptures, suggesting that a rapid increase in resistance could indicate a failure.
  • Others mention the micromagnetic method, specifically Barkhausen Noise Analysis, as a potential technique for detecting flaws in the metal film.
  • A participant describes a method involving alternating flux lines and resistance measurement to detect subsurface flaws, drawing parallels to gear manufacturing.
  • There is a suggestion to use bright light or laser reflection to detect openings, potentially utilizing a photodiode for light detection.
  • One participant raises questions about the specifics of the material's resistivity and whether measurements would be conducted prior to installation or in situ.
  • Concerns are expressed regarding the suitability of eddy current probes for continuous monitoring without overheating, as well as the potential use of piezoelectric or acoustic methods to detect changes in vibration characteristics when fluid escapes.
  • Another participant clarifies that the detection is aimed at identifying pinholes rather than pre-existing scores, emphasizing the need for continuous monitoring during operation.
Participants express a variety of techniques and approaches, but there is no consensus on a single method for detecting pinholes in the thin metal film. Multiple competing views and techniques remain under consideration.
Participants discuss the limitations of their proposed methods, including the need for non-contact measurements, the specifics of the material properties, and the operational conditions under which detection must occur.
Engineers and researchers working with thin metal films in applications involving pressure differentials, as well as those interested in non-destructive testing methods for detecting material flaws.
ummux
The thin metal film is scored with some pattern to 50-80% of its thickness. When exerted shear stress, the film will crack/open at score. I wonder what simple/practical techniques can be used to detect its pinhole or opening in real time?
Micromagnetic Method (Barkhausen Noise Analysis)
this is a technique we use to check for grind burn when making gears..the gear grinder may over heat the metal during machining and cause sub surface flaws that can not be detected.
so by placing a probe on the surface and generating flux lines ( alternating) you then use another probe to scan the surface..and check for resistance..a good gear will have a low current reading since the surface is a good conductor
a flawed or cracked surface will require more current..and you have indication of cracks..
Thank you. Our thin metal disc is used inside a pipeline and block fluid from one side to the other. When over pressure, it breaks at score and release fluid. Need to send fail-safe signal as breaking.
This method also report peak signal in score area without breaking through. I also hope to use some non-moving part ( no scan) as detector and don't use analysis tools (idealy by using electric circuitry and filter or bridges)
Any simple technology can be applied, which is sensitive to examining metal film (0.005 inch in thickness or so) rupture (break-through, not surface crack) ?
Andy Resnick said:
Electrical resistance?
Thank you , Andy.
Do you have some idea on how to measure the change in resistance of such disc (say 6in in diameter and 0.005in in thickness)? The resistivity of metal is about 10E-8. This is a nice idea (simple to implement) if I find a way to measure the R properly.
Do you mean 1.0 x 10^-8 ohm meters? (copper is about 1.5 x 10^-8 ohm meters) Is this a measurement prior to installation, or an in-situ measurement? Is this a magnetic or non magnetic material (e.g., nickel or copper) ? Are you looking for scores or pinholes? How long a score? I presume this is a non-contact measurement. Eddy current tests in the 10-100 kHz using a ferrite pickup are a good way for detecting scores, but not pinholes.
Bright light or laser shining through or being reflected off of the metal? You could pick up the light with a photodiode.
ummux said:
Thank you , Andy.
I'm vaguely familiar with your application, but not the specifics. I was assuming some sort of rapid and catastrophic rupture occurs, so I was just thinking to apply contacts on either side of the score- when the disc ruptures, the resistance would very rapidly increase.
Engineering fail-safe signals is not something I have experinece with, tho.
It should be easy enough to establish a proof-of-concept with a simple multimeter and a couple of leads.
My application is:
1. Disc material is stainless steel (resistivity is 7.5E-7ohm-m, non magnetic) but sometimes uses nickel (magnetic).
2. The examination is done when it is installed in the pipeline but we can isolate the disc from the disc at the flange.
3. Score is pre-made and I am not to detect it. It is a circular line on the surface. If there is weakness on some part of the score and further into a pinhole, that is the part to inspect.
4. If the disc is full open at all area of the score I can detect so my problem is only to detect if there is pinhole on the score.
5. I try to look for either electrical or electromagnetic technology in use, but did not find a way out.
Are you talking about detecting it while it is opening, or before it opens? Will this detection device be installed 100% of the time or used only during inspection? Can something be attached to the foil, or is this a non-contact measurement? What is the pressure difference across this foil? I have seen foils like this used up to 15 psi (vacuum).
I detect the disc immediately after a opening (either fully tearing at score or a small slit/pinhole, the latter is for this discussion) and the examination is continuous during pipeline process for maybe 24 hours or more. One side of the film is fluid (liquid or gas) the other is atmeosphere. Sensor can be attached to the foil and it should only at the atmosphere side.
So I hope some simply, small power consumption sensing element will work for this.
1. Is Eddy Current probe suitable for continuous working without overheat problem?
2. Can piezo-electric and/or acoustic work for it? If fluid come out of the film, the vibration character is changed. If so, where I can find the dynamic model to start with, and is it easy to filter the pipe noise?
  • · Replies 0 ·
  • · Replies 20 ·
