Tensile Stress-Strain: Ultimate Strain of Plain Concrete
The discussion revolves around the tensile stress-strain characteristics of plain concrete, particularly focusing on how to derive the tensile stress-strain curve from a compression curve, and the concept of ultimate tensile strain in concrete.
  • One participant inquires about plotting the tensile stress-strain curve using the tangent or secant modulus from a compression curve.
  • Another participant asserts that the tensile and compressive stress capabilities of concrete are fundamentally different, indicating that one cannot derive the tensile stress-strain curve from the compression curve.
  • A participant mentions typical ultimate tensile strength (UTS) values for concrete, noting that UTS in compression is around +/- 50 MPa, while in tension it is about +/- 5 MPa.
  • There is a question about whether it is possible to plot the tensile stress-strain curve using the secant modulus.
  • A response indicates that while it is possible to plot the tensile stress-strain curve, it does not resemble the compression curve and suggests that the secant modulus is not typically used for this purpose.
Participants express disagreement regarding the ability to derive the tensile stress-strain curve from the compression curve, with some asserting it is not possible due to the differences in material behavior under tension and compression. The discussion remains unresolved on the specifics of plotting the tensile curve.
There are limitations regarding the assumptions made about concrete quality and the definitions of ultimate tensile strain and strength, which are not fully explored in the discussion.
razq
Hi
If i have the stress-strain curve of concrete(compression) then how do i plot the SS curve for tension with reference with tangent modulus or secant modulus??
what is the ultimate tensile strain of plain concrete?
You cannot deduct SS curve for tension from compression curve.
especially for concrete as tension and compression stress capabilities for this material are completely different.
UTS compression for concrete is typically +/- 50MPa, depending on concrete quality/type ofc.
UTs tension +/-5 MPa
dear Alex.malh
UTS = ultimate tensile strain and see my first post. Be sure to check what concrete quality you have and check google afterwards.
there is something to plot the tension SS curve from secant modulus..?
Yes, you can but it's not really a curve like the compression curve and technically you don't use the secant modulus.
