Tension and Centripetal Force in Circular Motion
2 replies · 3K views · last reply
Lori
Physics problem diagram: a ball of mass 3.0 kg hung by two wires from a horizontal arm on a vertical shaft, with labelled lengths 0.8 m, 1.0 m and 0.6 m, angle theta = tan^-1(0.6/0.8) = 36.9 degrees, and handwritten working T2 cos theta = mv^2/R giving T2 = 29 N; a free-body force diagram with T1, T2 and W is shown beside it.
Where does T2cos(theta) come from ? Isn't mv^2/R the centripetal force which is the tension of rope 2?
Fc = mv^2/R
3. Solution
Wait! The horizontal component of the circle is the centripetal force? So that part is mv^2/R?
I got confused and thought the tension of rope 2 is actually the centripetal force. But if the x point of that tension is the centripetal force, i see how they got T2Cos
since cos(theta) = Xcomp/T2
i get cos(theta) = (mv^2/R)/T2
so that T2cos(theta)= (mv^2/R)[/B]
  • Physics problem diagram: a ball of mass 3.0 kg hung by two wires from a horizontal arm on a vertical shaft, with labelled lengths 0.8 m, 1.0 m and 0.6 m, angle theta = tan^-1(0.6/0.8) = 36.9 degrees, and handwritten working T2 cos theta = mv^2/R giving T2 = 29 N; a free-body force diagram with T1, T2 and W is shown beside it.
  • Handwritten solution on a physics problem sheet: a ball of mass 3.0 kg on two wires from a horizontal arm on a rotating vertical shaft, with the force diagram, tan(theta) = 0.6/0.8 = 36.9 degrees, and T2 cos(theta) = mv^2/R giving T2 = 29 N.
Yes, the ball is moving in a horizontal circle as shown below. The centripetal force must point from the ball toward the center of the circle. You can see that the x-component of T2 is the only force acting on the ball in this direction. So, the centripetal force is T2cosθ.
Diagram of a conical pendulum: a ball on a string at 1.0 m length, at angle θ from a vertical rod, with a horizontal bar of 0.8 m and a 0.6 m segment, a red horizontal circular path, tension T2 along the string, and its horizontal component T2 cos θ pointing toward the axis.
  • Diagram of a conical pendulum: a ball on a string at 1.0 m length, at angle θ from a vertical rod, with a horizontal bar of 0.8 m and a 0.6 m segment, a red horizontal circular path, tension T2 along the string, and its horizontal component T2 cos θ pointing toward the axis.
Thank you. Your drawing really made sense of this all!
