Tension in a rope due to hanging mass
The discussion focuses on understanding the tension in a rope due to hanging masses and how it relates to wave speed. It emphasizes that in a massless string, tension remains constant throughout its length, acting along the rope and at both ends. The net force on each block is zero, indicating that tension equals the weight of the mass (T = mg). Clarifications are sought regarding the role of forces from the wall and the interaction between multiple blocks. The conversation highlights the importance of free-body diagrams to visualize these forces accurately.
jegues
See figure attached for problem statement as well as my FBD.
I know how to relate the wave speed to the tension in the string.
v = \sqrt{\frac{\tau}{\mu}}
So as tension increases, so does the wave speed.
But how are the tensions in these two scenarios identical?
I think I can reason it out with words but I'd like to have the math to back it up.
Can someone clarify?
The masses are in rest. What does it mean for the tensions in all cases?
ehild
since net force on each block = 0, T = mg
Yes, but does the wall exert a force as well? Also, what happens in the case of the two blocks, they both pull down with a force a mg, so to the do tension forces oppose each other on the rope?
There is one tension in one rope and it acts along the rope, at both ends. A force equal to the tension acts upward to the block and on the right at the wall. The wall acts only to the rope according to Newton's third law. In case of two blocks, the forces acting on both blocks are the same and equal to the tension in the rope.
ehild
in am massless string the tension is same throughout and acts along its length at the end points (same as in a spring) . the wall will exert a force on the rope and not on the block.
ehild
Is this what the forces look like then?
See figure attached.
It is right, Jeques, but you need the magnitude of the tension. From your drawing you can only conclude that T-T =0 and Twall-T =0 Draw the forces acting on the blocks with arrows starting at the blocks. That is what a free-body diagram means.
ehild
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 18 ·
