Tension in the string and the normal force exerted by the wall
The discussion centers on the tension in a string and the normal force exerted by a smooth wall on a uniform solid disk of mass M and radius R. The participants derive equations for tension (T) and normal force (N) using trigonometric relationships, leading to conflicting results with a textbook solution. Key equations include TsinA = N and TcosA = Mg, with the book suggesting T = MgcosA and N = MgsinA. Participants conclude that the book's answers are incorrect, as the tension must be greater than or equal to the weight of the disk due to the absence of friction from the wall.
  • Understanding of static equilibrium in physics
  • Knowledge of trigonometric functions and their application in force analysis
  • Familiarity with the concepts of tension and normal force
  • Basic principles of rotational dynamics and torque
  • Review the principles of static equilibrium in two-dimensional systems
  • Study the derivation of forces acting on objects in static conditions
  • Explore the effects of frictionless surfaces on force interactions
  • Investigate torque and its implications in rotational motion
Students of physics, particularly those studying mechanics, educators seeking clarification on static equilibrium problems, and anyone analyzing forces in systems involving tension and normal forces.
StephenPrivitera
A uniform solid disk of mass M and radius R hangs from a string of length l attached to a smooth wall. We want the tension in the string and the normal force exerted by the wall.
|\ <--- I call this angle A
|_\
|__\
|_(..) <--- that's a disk
So I have it set up so the tension points up and to the left, the normal exactly to the right and the weight exactly down. The answer appears to take the normal perpendicular to the tension, which quite confuses me. Anyway, I get
TsinA=N
TcosA=Mg
so N=MgtanA
and T=Mg/cosA
The book gets T=MgcosA
and N=MgsinA
Change your coordinates to where T is straight up the vertical. This will give you the right answers.
I see that it works for the tension. Doesn't the normal have to be perpendicular to the wall? If it is then mgsinA is not N.
Yep
mg*Sin(A) is perpendicular to wall.
How can that be? There is no component of the weight that is perpendicular to the wall. MgsinA is perpendicular to the tension, which is not perpendicular to the wall.
y
Here is something to think about: In order for the system to remain static, what must the normal force be?
The normal force acts horizontally. In order for the system to have zero horizontal linear acceleration, the normal force must be equal in magnitude and opposite in sign to the sum of the other horizontal force. The weight acts down. Its horizontal component is 0. The tension has a horizontal component TsinA. We must have N-TsinA=0 or N=TsinA, which is not the correct result.
I'm very confused. Why do I get different answers for the tension doing the problem two different ways? My way seems perfectly right and the book's way seems perfectly right.
Unless I'm missing something, the magnitude of tension cannot be less than the weight of the disk, because tension is the only force opposing gravity.
(incidentally, is the string attached to the center of the disk?)
No. It's attached to the edge of the disk.
So IOW, the book must be wrong?
Smooth walls can supply no frictional force to disks, right? If so, tension is the only force with an upwards component, and thus must be no less in magnitude than mg, so the book would have to be wrong...
I don't know what you mean by "attached to the edge". The line of the string, if extended, passes through the center of the disk, right? If not, the string would exert a torque on the disk, rotating it.
In any case, your thinking seems correct. The book's answer does not.
Stephen, your picture seems to show the disk horizontal with, as yo say, the string at the edge. What keeps the disk from falling straight down? Is the disk attached to the wall also or is there a friction force there?
Yes.
I'm sorry that description wasn't very clear. The string, if extended past the edge, would go through the center. You can say it is attached to the center if you wish without affecting the result, except for the fact that when I say the string has length l, I mean the distance from the edge of the disk to the wall where the string is attached is l. The distance to the center is l+R.
The wall is smooth, no friction.
I have spoken with my professor, and he is also confused by the book's answer.
  • · Replies 21 ·
