Tension in the string holding a falling chain
37 replies · 8K views · last reply
Homework Helper
- Messages
- 14,830
- Reaction score
- 4,812
No parts of the left side are in free fall. All parts of the left side are at rest. The left side is just getting longer as more links are added to the left side.Vibhor said:Which part of the string is in free fall ?Is left part in free fall ?
YesAre you suggesting that only the right part is in free fall ?
Can you show how you get the answer assuming the left side is in free fall?Why do we get correct answer by assuming left part to be in free fall ?
Vibhor
- Messages
- 971
- Reaction score
- 40
TSny said:Can you show how you get the answer assuming the left side is in free fall?
Thrust force is λv2 . If we assume tip of left string to be in free fall ,it falls by a distance y/2 . Hence the speed is √(2g(y/2)). This is how I got the thrust force λgy .
Homework Helper
- Messages
- 14,830
- Reaction score
- 4,812
I'm afraid I don't follow your argument.Vibhor said:Thrust force is λv2 . If we assume tip of left string to be in free fall ,it falls by a distance y/2 . Hence the speed is √(2g(y/2)). This is how I got the thrust force λgy .
haruspex outlined how to get the force in #27.
The rate, dm/dt, at which mass on the right is coming to rest is the rate at which mass on the right is reaching the (moving) blue line. This is λ times the velocity of the right side relative to the blue line: dm/dt = λ(vred dot - vblue line) =λ(v - v/2) = λv/2, where v is the velocity of free fall of the right side: v = √(2gy). The magnitude of the force required to bring elements of the right side to rest is equal to the magnitude of the rate of change of momentum of these elements:
F = (dm/dt)⋅v = (λv/2)⋅v = λv2/2 = λgy.
Vibhor
- Messages
- 971
- Reaction score
- 40
TSny said:The rate, dm/dt, at which mass on the right is coming to rest is the rate at which mass on the right is reaching the (moving) blue line. This is λ times the velocity of the right side relative to the blue line: dm/dt = λ(vred dot - vblue line) =λ(v - v/2) = λv/2, where v is the velocity of free fall of the right side: v = √(2gy). The magnitude of the force required to bring elements of the right side to rest is equal to the magnitude of the rate of change of momentum of these elements:
Thanks .This clears up the confusion.
Vibhor
- Messages
- 971
- Reaction score
- 40
TSny said:I'm afraid I don't follow your argument.
Now ,even I don't follow my argument
The remarkable thing is that ,despite getting the dynamics of the problem wrong in every step ,I got the correct answer in first try
- Tibriel
- · Replies 3 ·
- Introductory Physics Homework Help
- Replies
- 3
- Rikudo
- · Replies 4 ·
- Replies
- 4
- phantomvommand
- · Replies 7 ·
- Replies
- 7
- LCSphysicist
- · Replies 2 ·
- Replies
- 2
- Alice Martin
- · Replies 3 ·
- Replies
- 3
- al_9591
- · Replies 5 ·
- Replies
- 5
- DLH112
- · Replies 3 ·
- Replies
- 3
- Jordan&physics
- · Replies 2 ·
- Replies
- 2
- saurabheights
- · Replies 3 ·
- Replies
- 3
- manosairfoil
- · Replies 6 ·
- Replies
- 6
