Tension of a rope with a hanging mass and acceleration
The discussion revolves around determining the tension in a rope with a hanging mass of 0.5 kg that is falling with an acceleration of 0.44 m/s². Participants explore the relationships between tension, gravitational force, and acceleration in this context.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the equations for tension, questioning the correct formulation and the effects of gravity and acceleration on tension. There are attempts to derive the tension using different frames of reference and free-body diagrams.
There is an active exploration of the relationships between the forces acting on the mass, with some participants providing insights and corrections to earlier statements. Multiple interpretations of the equations are being examined, and guidance is being offered regarding the setup of the problem.
Some participants mention the presence of a flywheel, which may influence the dynamics of the system. There are also references to different frames of reference, which complicate the understanding of the forces involved.
justadaftspark
Find the tension of a rope with a hanging mass of 0.5kg that falls with an acceleration of 0.44ms^2
T = ma
T = ma-mg
T = mg = 0.5*9.81 = 4.905N, I would assume that this is correct for a static load on the rope ?
My question is. How does the relationship between gravity and acceleration act on the tension of the rope? Is the correct equation
T = mg-ma ?
Any help would be appreciated
Yes, t = mg - ma. But, for clarity, draw a free-body diagram of the block and sum your forces.
Thanks,
Tension acts in an upward direction
Gravity acts in an downward direction
Acceleration acts in a downward direction
so i get T-ma-mg = 0
transpose to get T = mg+ma
Or am i looking at acceleration going in the wrong direction ?
I apologize, my previous statement was incorrect. Since the mass is moving downward, the tension has to support the accelerations of both gravity and of the mass, and thus T = m(g+a).
Your second statement is correct.
From an inertial frame of reference ( say, a person standing on the ground) assuming the downward direction to be +ve, ma = mg - T.
For a person standing on the ground ma would equal m, correct? no acceleration
Transpose ma=mg-T for T
T=mg-ma ?
can someone explain why it is either g-a or g+a. This may be simple but I am not getting it
Sorry i mean to say that the person on the ground ma would equal mg
No I think according to the question, the person on the ground sees it coming down with an acceleration of a=0.44m/s2. So ma=mg -T.
So we are saying that
ma=mg-T
T= m(g-a)
T= 0.5(9.81-0.44) = 4.685N in an upward direction
Sunil Simha, where did i go wrong in post #3?
ma=mg-T
T= m(g-a)
I think you took the frame of reference of the falling block. Is that right?
If yes, ma would be a pseudo force in upward direction and thus the equation would be T+ma=mg as the block is in rest in its own frame.
If not, then maybe you took the frame of reference of the ground in which case the force equation would still be the same i.e. ma=mg-T.
I maybe should have mentioned that the rope is on a flywheel
would it be that acceleration (0.44) is working against gravity as it is slower?
Check out my attachment... Is it the correct diagram?
If yes then you can see the force equations.
If no, I'm sorry for the inconvenience:redface:
Not an inconvenience at all mate, thank you for all your patience and help.
I am trying to understand why the equation is the way it is.
Yes my diagram is similar but without the rope on the left hand side being pulled
to re cap
T= up
mg= down
ma=down
thus T-mg-ma = 0 correct?
The mass is allowed to fall at a rate of 0.44ms^-2
to re cap
T= up
mg= down
ma=down
You see, ma is actually the resultant of mg and T, right? Because (in the frame of reference of the ground) they are the only two forces acting on the block. So ma=mg-T.
Ahh... big help with
t = mg
Not sure where you are in the world but you may have heard the penny drop.
Thanks again Sunil Simha.
  • · Replies 22 ·
  • · Replies 38 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 21 ·
