Tension on a Massive Rope: How to Calculate Tension at Different Points
  • Thread starter Thread starter SakuRERE
    Rope Tension
The discussion focuses on calculating the tension in a rope system subjected to an applied force of 9.0 N, with a total mass of 0.3 kg (including two blocks and the rope). The acceleration of the system is determined to be 20 m/s² using Newton's second law, Fnet = ma. The tension at the top of the rope is calculated to be 68 N, while the tension at the bottom of one-fifth of the rope requires further clarification on the mass considered. Participants emphasize the importance of accounting for gravitational forces in these calculations.
  • Understanding of Newton's second law (Fnet = ma)
  • Basic knowledge of gravitational force calculations
  • Familiarity with tension in rope systems
  • Ability to manipulate algebraic equations for physics problems
  • Review Newton's second law and its applications in dynamic systems
  • Study gravitational force calculations in multi-body systems
  • Learn about tension distribution in ropes with varying mass
  • Practice solving similar physics problems involving forces and tensions
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for examples of tension calculations in rope systems.
SakuRERE
A system, consisting of a wide rope of mass 0.10 kg between two blocks each of mass 0.10 kg, is lifted by an applied force F = 9.0 N (Fig. 4 below). (a) Find the acceleration of the system. Find the tension at (b) the top of the rope, and (c) the bottom of one-fifth of the rope. Take g = 10 m/s2.
Fnet=ma
a) Fnet=ma
F- 3mg = ma
9- 3(0.1)(10) = 0.1a
6=0.1 a
a= 60 m/s^2
b) T- 2mg = ma
T-2(0.10)(10) = 0.10(60) (it's right to use the mass of rope by acceleration right?)
T-2=66
Ttop= 68N
is it right?
c) T- (4/5x m)- 10xm= (4/5)m x a
T- 0.08(10) - (0.10)(10)= 0.08(60) is this equation right
i don't if i got (the bottom of one-fifth of the rope) correctly or not. i considered the tension to equal to that part of the rope below 1/5 from the mass so that m of rope now is 4/5m
and also i have the lower mass (m). so is it right??
SakuRERE said:
a) Fnet=ma
F- 3mg = ma
6=0.1 a
a= 60 m/s^2
Doesn't that seem a bit high to you?
SakuRERE said:
b) T- 2mg = ma
T-2=66
Ttop= 68N
is it right?
You have a ##9N## force and a tension of ##68N## Does that makes sense?
it does, that's why I am asking here. i get number that are too big
What is the mass of your system?
What is the net external force on your system?
What is the acceleration of your system?
the total mass is 3(0.10) the two blocks and the rope
fnet is 9N
the acceleration... do you mean it should be F- 3(mg)=3ma?
If you mean: The total mass is ##0.3kg##, then yes.
SakuRERE said:
fnet is 9N
What about gravity?
I didn't mean anything. I just asked a question!
PeroK said:
What about gravity?
the gravity force is down and each mass including the rope will have a weight downward.
Oh yeah, i am just trying to reach the solution fast :)
Exactly, so you need to take gravity into account when calculating the external force on your system.
i JUst checked again my solution and i must have put 3m in a)
F-3mg= (3M)a
right? so a=20
and regarding the b) it would be
T-2mg=2ma
right?
and for c)
it would be
T-(1/5x0.10)g - 0.10g = (1/5x0.10+ 0.10) (20)
right?
F-3mg= (3M)a
right? so a=20
20 what? Units are important.
T-2mg=2ma
right?
That's the idea. It's called Newton's 2nd Law!
a= 20 m/s^2
so it's right and i am done with it right?
SakuRERE said:
a= 20 m/s^2
You just have to calcuate the tension.
  • · Replies 38 ·
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 39 ·
  • · Replies 16 ·
9K
  • · Replies 18 ·
