Tension on two chains holding a board
  • Thread starter Thread starter Physsics
    Board Tension
The discussion centers on calculating the tension in two vertical chains supporting a horizontal board with a weight of 125 N and a person weighing 500 N sitting on it. The tension in the right chain is initially assumed to be 250 N, but further analysis reveals that both chains must support the total downward force of 625 N (125 N board + 500 N person). Using equilibrium principles, the tension in the left chain can be determined as well. The equilibrium condition requires that the sum of vertical forces equals zero, leading to the conclusion that the tension in both chains must be equal.
  • Understanding of static equilibrium principles
  • Ability to draw and interpret free body diagrams
  • Knowledge of forces and tension in physics
  • Familiarity with the concept of net force being zero
  • Study the principles of static equilibrium in physics
  • Learn how to construct and analyze free body diagrams
  • Explore calculations involving tension in multiple support systems
  • Review examples of problems involving forces acting on beams and boards
This discussion is beneficial for physics students, educators, and anyone interested in understanding the mechanics of forces and tension in static systems.
Physsics
A horizontal, uniform board of weight 125 N and length 4 m is supported by vertical chains at each end. A person weighting 500 N is sitting on the board. The tension in the right chain is:
a) 250 N
b) 375 N
c) 500 N
d) 625 N
e) 875 N
How far is the person from the left end of the board?
a) .4 m
b) 1.5 m
c) 2 m
d) 2.5 m
e) 3 m
I really have no idea how to do this one; wouldn't you have to know how far the person is from one of the sides first to know what the tension is on one side?
This is my first post here, so I hope I didn't do something wrong :)
Start by drawing a free body diagram and then use the fact that the board is in equilibrium.
So the body is 500 N downwards, while the 250 N tension, the unknown tension of the second chain, and the 125 N board all oppose it, and the fact that it's in equilibrium means that the sum of all the net forces is 0, but what after that?
How did you get the tension in the left chain?
I didn't, I just said that one of the chains (presumably the right chain) has a tension of 250 N.
Well you'd have the two weights downwards and the two tensions upwards. Then you should be able to use ∑Fy=0 to get the tensions as they should be the same.
