Calculating Tension in a Revolving Mass: Homework Solution
The problem involves calculating the tension in two wires supporting a 970g mass revolving horizontally at 7.5 m/s. The forces in both the vertical and horizontal directions are analyzed, leading to the equations for tension in the upper and lower wires. The vertical force balance yields T1 in terms of T2 and gravitational force, while the horizontal balance relates the tensions to the centripetal force. After solving the equations, the tension in the lower wire (T2) is found to be approximately 26.868 N, and substituting this back gives the tension in the upper wire (T1) as 46 N. The calculations confirm the results are consistent and accurate.
sunnnystrong
The figure shows two wires that are tied to a 970g mass which revolves in a horizontal circle at a constant 7.5 m/s. What is the tension in the upper wire?
The wires are both 1m long, and are attached to a pole. The radius is cos(30 degrees). It's an equilateral triangle.
∑F = m*a
[/B]
∑Fy = 0.
∑Fx = (m*v^2) / r
First I looked at the forces in the y-direction. Down = negative.
The upper rope = T1. The lower rope = T2.
(.5)T1 - (.5)T2 - mg = 0
*Solve for T1*
T2 + 2*m*g = T1 // EQN 1
Next, in the X-Direction. Inward = positive.
T1cos(30) + T2cos(30) = (m*v^2)/r
Plug in value for T1 to solve for T2.
2*T2*cos(30) + 2*m*g*cos(30) = (m*v^2)/r
[(m*v^2)/r - 2*m*g*cos(30) ] / (2cos(30) = T2
T2 = 26.868 N
Plug into EQN 1 and I got T1 = 46 N
Looks good.
Likes sunnnystrong
gneill said:
Looks good.
Thank you!
