Why is [G] Sandwiched by Epsilon Inverses in Tensor Inverse Calculation?
The discussion focuses on the mathematical reasoning behind the placement of [G] between epsilon inverses in tensor inverse calculations. Participants highlight the use of binomial expansion and the importance of proper mathematical notation to avoid errors in matrix algebra. A corrected approach is suggested, emphasizing the need to factor out epsilon to simplify the expression. The conversation underscores the significance of clarity in mathematical communication among scientists and engineers. Ultimately, the clarification leads to an understanding of the initial mistake made in the calculations.
Motocross9
Given $$\varepsilon^{'}=\varepsilon+i\epsilon_{0}[G]$$
$$(\varepsilon^{'}$$ is a hermitian, second rank tensor) show that
$$\varepsilon^{'-1}=\varepsilon^{-1}-i\epsilon_{0}\varepsilon^{-1}[G]\varepsilon^{-1}$$, note that $$[G]$$ is small. Also, $$\varepsilon$$ is a diagonal second rank tensor, and $$[G]$$ is a real antisymmetric matrix.
$$\varepsilon^{'}=\varepsilon+i\epsilon_{0}*[G]$$
Clearly, they used the binomial expansion on this; however, I cannot figure out why [G] is sandwiched by the epsilon inverses:
$$\varepsilon^{'-1}=1/(\varepsilon+i\epsilon_{0}[G])\approx(1-i\epsilon_{0}[G]\varepsilon^{-1})\varepsilon^{-1}$$
Hi Motocross9,
While most of us who are scientists or engineers use abusive (incorrect!) mathematical notation at times, in this case I think it is causing you to make mistakes in elementary matrix algebra. Using more proper notation, you first step is something like this
\begin{eqnarray}
\left[ \epsilon + i \epsilon_0 G \right]^{-1} & = & \left[ \epsilon \left( I + i \epsilon_0 \epsilon^{-1} G \right) \right]^{-1}.
\end{eqnarray}
What do you get if you continue from here?
jason
jasonRF said:
Hi Motocross9,
\begin{eqnarray}
\end{eqnarray}
jason
Thanks so much! I see my mistake now.
