Terminal velocity of loop falling through magnetic field
The discussion focuses on calculating the terminal velocity of a loop falling through a magnetic field. The initial approach equates gravitational force to magnetic force, leading to the equation v_t = mg/B. However, it is pointed out that this method overlooks energy considerations, specifically the power loss due to resistance in the loop as velocity increases. The correct approach requires balancing the power loss from the induced current with the mechanical power supplied by gravity. Ultimately, the dimensions of the square loop do not affect the final outcome, emphasizing the importance of energy dynamics in the analysis.
Rawl
https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/72/72755-bc8e4b32405460abcfa2d8e4880f7037.jpg
I'm trying to figure out the terminal velocity of the loop as it falls through the magnetic field (figure 7.20).
3. The Attempt at a Solution
The terminal velocity will happen when
\vec{F} = 0
i.e.
mg = \vec{f}_{mag}
But we know:
\oint \vec{f}_{mag} . d\vec{l} = vBl
So
\vec{f}_{mag} = vB
v_t = \frac{mg}{B}
Why is this wrong?
You have to regard the energy/power in the system. The square loop has some dimensions which have influence in the resistance, R, of the loop. So as the velocity of the loop increases, the voltage and thus the current will increase, leading to a power loss = I2 * R.
This power loss must match the mechanical power supplied = m*g*v.
See the note: The dimensions of the square will cancel out.
It think it's right.
  • · Replies 25 ·
  • · Replies 18 ·
