Thanks again.Identification Algorithm for Parameter-Varying System?
The discussion focuses on identifying parameters in a parameter-varying system using differential and algebraic equations. The user has input and output measurements and is attempting to identify 24 parameters derived from 8 expressions, each containing 3 parameters. Previous attempts with algorithms such as least squares, gradient descent, and Newton-Raphson have been unsuccessful. The user seeks advice on effective identification algorithms suitable for their specific engineering problem.
  • Understanding of parameter-varying systems
  • Familiarity with differential and algebraic equations
  • Knowledge of parameter identification algorithms
  • Experience with optimization techniques such as least squares and gradient descent
  • Research advanced parameter identification techniques for time-varying systems
  • Explore the use of Kalman filters for real-time parameter estimation
  • Investigate the application of genetic algorithms in parameter optimization
  • Learn about system sensitivity analysis to improve parameter estimation
Engineers and researchers working on system identification, particularly those dealing with parameter-varying systems and optimization challenges in modeling and simulation.
FaroukSchw
Hello everybody
I started recently working on an engineering problem that requires as a first step, the identification of the system.
I already have a model which is a set of differential and algerbraic equations. Unfortunatelly, the system is a parameter varying one, and the aime is to identify these parameters. Taking in consideration that i have input and output measurements, and about 20 parameter to identify.
Does anyone have an idea about an identification algorithm that can be used for such problem?
Regards.
It really doesn't make much sense to estimate the parameters of a time-varying system, unless you have the model for the time dependence of the parameters as well (periodicity, explicit functional form?) or you have some specific real-time application that I can't think off right now. Anyway, I'd really appreciate it if you'd share your models and tell us what you're trying to do
Hi elibj123
Thanks for taking time and responding to my thread.
In fact, i do have the expressions of the parameters, but since the model has 8 parameters, each parameter's expression contains three parameters, so 8*3=24 paameter to be identified.
The sensitivity of the model to the parameters varries from one parameter to an other.
I tried some algorithms such as different versions of the least squares, Gradient algo, Newton-Raphson, but they don't work!
Unfortunatelly, i can't share the model, because i don't have the right to, at least for the time beying.:frown:
I will be verry glad if you can provide some advices.
  • · Replies 38 ·
