Thanks for the Help, Got It Sorted!
  • Thread starter Thread starter Jack Jiang
    Thanks
The discussion focuses on optimizing the dimensions of a right circular cylinder oil can with a volume of 54π cubic inches to minimize material use. The minimum radius determined is 3 inches. The volume formula V = πr²h is used to express height in terms of radius, while the surface area A = 2πrh + 2πr² is derived for optimization. Participants confirm that the first derivative method is appropriate for finding the minimum surface area. The conversation concludes with agreement on the calculated dimensions.
Jack Jiang
Got It, Thanks Guys
Mathematics news on Phys.org
Jack Jiang said:
An oil can is to be made in the form of a right circular cylinder to contain 54pi cubic inches. what dimensions of the can will require the least amt. of material.did anyone get the radius to equal 3?
Right on, the min is 3.
V=(Pi)R^2=54(Pi)
A=2(Pi)RH+2(Pi)R^2
Solve for H in volume, find minimum through first derivative.
V = \pi r^{2}h
Thus
A = 2\pi rh + 2\pi r^{2}
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
