The angular velocity of a process control motor is (21−(1/2t^2)) rad/s
The angular velocity of a process control motor is defined by the equation (21−(1/2t^2)) rad/s. The motor reverses direction at t = 6.5 seconds, determined by setting the angular velocity equation to zero. To find the angle through which the motor turns before reversing, one must integrate the angular velocity function, resulting in the angular displacement equation θ(t) = 21t - (1/6)t^3 + C. Evaluating this integral from t = 0 to t = 6.5 seconds provides the total angular displacement.
  • Understanding of calculus, specifically integration and differentiation
  • Familiarity with angular motion concepts, including angular velocity and displacement
  • Knowledge of the relationship between linear and rotational motion
  • Ability to solve polynomial equations
  • Learn how to integrate functions in calculus to find displacement from velocity
  • Study the relationship between angular velocity and angular displacement in rotational dynamics
  • Explore the concept of definite integrals and their application in physics problems
  • Review the principles of motion under constant acceleration to understand angular acceleration
Students studying physics, particularly those focusing on mechanics and rotational motion, as well as educators looking for examples of calculus applications in real-world scenarios.
zapzapper
The angular velocity of a process control motor is (21−(1/2t^2)) rad/s, where t is in seconds.
1.) At what time does the motor reverse direction?
2.) Through what angle does the motor turn between t =0 s and the instant at which it reverses direction?
For part 1 I just set the equation equal to 0 and got a time of 6.5 sec, which is correct
For part 2, I have no idea what to do. Nothing is working, so if you could help, that would be great! I have tried taking the derivative to find acceleration, which is -t, and then plugging that into θf = θi + ωi(t) + 1/2a(t^2). I set θi = 0 because I figured there would initially be no angle. I set ωi = 21 because at t=0, ω = 21. I set t= 6.5, and a=-6.5...so my equation was θf = 0 + 21(6.5s) + 1/2(-6.5)(6.5s^2), but the answer came to like -0.8125 rad? is that right? it seems odd to me...
Hi zapzapper, Welcome to Physics Forums.
It appears that you're familiar with calculus since you mentioned taking a derivative.
Suppose this were a linear motion problem and you were given a velocity function v(t). How would you go about finding d(t) using calculus? You can apply the same method to rotational motion where velocity is represented by the variable ω and distance by θ.
ok, I'll integrate the function
oh ok, so I just integrate the function then?, If I integrate it then I get (21t - (1/6t^3) + c), what do i do with the constant c though?
You are trying to find the total angular displacement between two known times. What happens to the constant of integration when you evaluate a definite integral?
  • · Replies 17 ·
