Does the Bullet Cluster Disprove MOND and Challenge ΛCDM?
  • Context: Graduate
  • Thread starter Thread starter Earnest Guest
    Bullet mond
The Bullet Cluster serves as a critical piece of evidence against Modified Newtonian Dynamics (MOND) and supports the ΛCDM model of cosmology. Observations indicate that gravitational lensing aligns with the visible mass of the cluster rather than the hot gas, suggesting that the majority of mass is in the form of dark matter. The collision velocity of the Bullet Cluster is consistent with ΛCDM, which effectively explains the separation of dark matter from baryonic matter during cluster collisions. This discussion highlights the inadequacies of MOND in explaining the Bullet Cluster's dynamics and reinforces the validity of the ΛCDM framework.
  • Understanding of gravitational lensing and its implications in astrophysics
  • Familiarity with ΛCDM (Lambda Cold Dark Matter) cosmological model
  • Knowledge of Modified Newtonian Dynamics (MOND) and its principles
  • Basic concepts of dark matter and baryonic matter in cosmology
  • Research the implications of gravitational lensing in cosmology
  • Study the principles and predictions of the ΛCDM model
  • Explore the limitations and criticisms of MOND in astrophysical contexts
  • Investigate the role of dark matter in galaxy formation and evolution
Astronomers, astrophysicists, cosmologists, and students interested in the dynamics of galaxy clusters and the ongoing debate between MOND and ΛCDM models.
  • #31
Earnest Guest: I think you've missed the point of the assumption of hydrostatic equilibrium. This assumption is not needed in order to measure the total mass of gas. The gas mass can be measured from the X-ray luminosity alone. The assumption of hydrostatic equilibrium is used to estimate the total gravitational mass of the cluster. This is why we believe that these clusters have a large component of dark matter. Without it, the pressure of the gas is large enough that the gas would basically blow away into intergalactic space.
Your question of what keeps the gas in these clusters hot (i.e. why don't they cool off and stop radiating?) is a good one, and it is an area of active research. It is believed that there are large energy outflows from super massive black holes in the massive galaxies near the cluster centers, and these energy outflows are continually stirring and heating the hot gas. However, this is only one hypothesis and there are other possibilities.
Space news on Phys.org
  • #32
phyzguy said:
They are two different things.
Yes, I see that now, but I still can't get my head around this basic physical fact: if the energy is not renewed, then the X-Ray radiation will cool down to the CMBR. Why do we assume that the radiation is from braking (which is a one-time energy output) and not from the pressure exerted on the gas by gravity (which would be a constant source of energy)?
  • #33
On MOND specifically, I think another problem is that there are many individual collisional clusters like the Bullet Cluster. IIRC astrophysicist Siegel has claimed that when you fudge MOND to fit one, it won't fit the rest, and so on. If there are tens of such cluster, and I think there is, the combinations of predictive fails increase at a staggering rate. (I should check all this, but I'll let it stand for the time being, I am procrastinating from a deadline.)
On inflationary LambdaCDM cosmology, besides that dark matter is observed in so many ways now, we should also mind that it has become the best theory predicting structures on _all_ scales. Specifically it does much better than MOND on galaxies:
Fig 2 – The left panel shows the velocity function, which is the number distribution of galaxies as a function of line of sight rotational velocity, Vlos. Ignoring the dark purple line which indicates maximum circular velocity for Cold Dark Matter (CDM), the DC14 model in red is contested against the NFW profile in light purple. The right figure relates Vlos with galaxy stellar mass M*, ie the Tully-Fisher relation. The data points are observational results. In both plots, the DC14 model closely tracks observations while the NFW profile deviates far from observations. Figure 2 from paper.
The DC14 is CDM in realistic galaxies with supernova outflows, and it matches observations.
"But what about alternative dark matter models like warm dark matter (WDM) and self-interacting dark matter (SIDM)? As we briefly touched in the beginning, they are partly conceived to resolve the cusp-core problem. In fact, WDM and SIDM are also mass-dependent like the DC14 model, but not in exactly the same way. So, how do they fare in predicting the velocity function and the Tully-Fisher relation for galaxies? Figure 3, our last figure of the day, shows exactly this. Despite doing better than the NFW profile, both WDM and SIDM are not able to fit the velocity function and Tully-Fisher relation as well as we expect."
Fig 3 – These are the same plots as Figure 3 with the left figures showing the velocity functions and the right figures showing the Tully-Fisher relations, but comparing warm dark matter (WDM) in blue and self-interacting dark matter (SIDM) in green against the NFW profile in purple. Figure 4 in paper.
[ http://astrobites.org/2015/06/12/the-labor-of-outflows-against-dark-matter-halo/ ]
If WDM and SIDM, who didn't have the CDM cusp-core problem, does as well as MOND, and now do worse than CDM - because the natural core cusp being obliterated by supernova flows is the correct physics - MOND should also follow the Fig 3 type of "fail" curve.
  • #34
I'm not sure what all that has to do with the estimation of cluster gas mass from X-Ray radiation. Could you connect the dots for me?
  • #35
The pressure exerted on the gas by gravity is not a source of energy. Power (rate of change of energy with time) is force dotted with velocity. So a constant force with no motion is not a source of energy. Just like a weight hanging on a hook requires no energy input, despite the constant gravitational force. So in order for the force of gravity to input energy into the gas, the gas would have to move in the direction of the gravitational force. In other words, the gas cloud would need to be collapsing under the influence of gravity. This is one possibility for the source of the energy input. We do not know for sure that these clusters are stable over very long times. However, we believe that they are relatively stable, and that there is a source of energy which is keeping them from collapsing.
Two other points. First - you say that without a source of energy input the gas would cool down to the temperature of the CMB. The is true, but this would take a very long time. The cooling time constants for these clouds of hot gas is billions of years, so the universe has not been around long enough for them to cool that much, even if there were no energy input.
Second, the radiation is almost certainly from bremsstrahlung - braking radiation. But your comment seems to imply that you are picturing the radiation as being due to the braking of the gas as a whole. This is not right. What is experiencing the "braking" is the individual electrons in the gas. An electron encounters a much heavier nucleus, and is accelerated from its interaction with the nucleus. Since an accelerated charge radiates, it emits radiation. The theory of bremsstrahlung is quite well understood, and the radiation from the hot gas in these clusters matches what we would expect quite well.
  • #36
Are you asking me about 'all that' (figures for rapid reading)? My comment should be self explanatory, but I'll repeat:
1. There are many clusters, so presumably many mutual failures in tests of MOND.
2. LambdaCDM is better than MOND or any other theory on structures at all scales, including those that MOND was ad hoc constructed to do a fair job on. (So why bother with the failures?)
  • #37
I don't want this discussion to devolve into a MOND vs LCDM discussion because I don't believe in either, but as long as you brought up failures, perhaps you should do some reading about LUX, the LHC and the Standard Model of Quantum Physics. LCDM works great except for the part where there's no candidates left for dark matter particles. Short story: if it existed at any of the possible energy levels, we would have found it by now in the LHC. If it interacted with matter, it would have sparked up the tank at LUX.
  • #38
Earnest Guest said:
Don't put words in my mouth. I mean the Second Law of Motion isn't accurate. The failure of MOND is related to their attempt to fix gravity, which works just fine.
Okay. But Newton's second law of motion is one of those things that is true by definition. It is a definition of what we mean when we used the word "force" in a Newtonian context. I don't think it's possible to get it wrong within the regime where Newtonian mechanics holds, which it definitely does here.
  • #39
Earnest Guest said:
OK, so then (1) how do you calculate the pressure and (2) will doubling the pressure double the temperature?
If you have the volume of the gas, you can calculate the pressure. This requires some assumptions about the extent of the cluster along the line of sight. One common assumption is to just assume it's spherical.
As for doubling the pressure, that depends. The gas is likely to change volume as well, so the resulting temperature change depends upon precisely how you change the pressure.
  • #40
Sort of. A self gravitating cloud of gas increases in temperature as it releases energy. This is why stars are hot, for example. As the cloud releases energy, it collapsed in on itself, reducing is volume and increasing its pressure. Because there is now more matter in a smaller volume, the gravitational attraction between the atoms in the gas also increases.
You can slow or stop the collapse by having some process dump energy into it. Stars stop collapsing for this reason: the nuclear furnace at their core provides a steady source of energy. Presumably the formation of galaxies within a cluster likewise slow the collapse of the cluster gas, particularly when AGN's turn on.
  • #41
Chalnoth said:
You can slow or stop the collapse by having some process dump energy into it. Stars stop collapsing for this reason: the nuclear furnace at their core provides a steady source of information. Presumably the formation of galaxies within a cluster likewise slow the collapse of the cluster gas, particularly when AGN's turn on.
So to wrap it up, the P = n k T relation isn't needed because the flux and the temperature can have only one density and you simply multiply that density by the volume to get the mass. So if you doubled the pressure, you'd double the flux, but the temperature would stay the same?
  • #42
Not quite. As I said earlier: it depends upon how the pressure is doubled. Would this be an isothermal process? An adiabatic process?
  • · Replies 41 ·
  • · Replies 0 ·
  • · Replies 35 ·
  • · Replies 17 ·
