The detector itself contaminating double slit? How do we know?
70 replies · 12K views
Nugatory said:
That I'll buy, but I still don't like thinking of it as the detector "messing up the experiment". I prefer thinking that we have two quantum systems (one particle+detector+screen and the other particle+screen).
Yea - that's all. A bit of semantic clearness in expressing this stuff helps in understanding it IMHO.
Thanks
Bill
I would still call that messing up the experiment. Excuse my laymen terminology... but these guys don't create experiments without expected results... they were expecting to see a single photon going through that's why they put the detector up to see where it went through. When they did that the wave form collapsed and they didn't see what they wanted to see, thus a messed up experiment and indication that they were missing something in the quantum theory...
Nugatory said:
I prefer thinking that we have two quantum systems (one particle+detector+screen and the other particle+screen). They're different systems so they evolve differently, but each one is still best considered as a complete system.
This is really to mattjfox:
In my example (post #29) there is ONE quantum system: particle+2 detectors+screen. The 2 detectors are physically alike. When oriented relative to each other one way (parallel), there IS interference. When oriented relative to each other another way (crossed), there is NO interference.
The point being is that the idea that anything is "messed up" is just not correct, period. This is a quantum system, and quantum rules apply. And it has nothing to do with the physical observation being the source of some alteration to the setup. Nothing need be observed at all, as a matter of fact, as this setup demonstrates. Just the relative orientation of the polarizers changes. And you can vary to any degree in between too, with predictable results.
That's because those are the results you are expecting after years of doing this. I am referring to when scientists first conducted the experiment and were surprised by the results.
Also I don't really get the validity of the polarization experiments. When you turn the lens 90 degrees from the other lens aren't you are essentially just blocking light from going through one of the holes. If I am understanding that correctly I am not sure how this method validates anything except recreating a 1 slit experiment where you get a blob of light instead of interference pattern again.
I'm not quite sure you got the technical bits about "collapse" quite correct. But anyway, let's say it's obvious now that single and double slit experiments give different results. Was there anything deeply wrong with say Feynman's surprise?
My thought is that "messed up" is correct in the sense that Feyman did get something deeply wrong. He meant to use the double slit to show that quantum mechanics is mysterious. Now that we can simply explain the double slit and single slits as different experiments, does that mean there is nothing mysterious about quantum mechanics? I think no - Feynman did not identify the true source of mystery, and that was a deep mistake.
The true source of mystery is not the double slit but in
(1) the classical/quantum split in the Copenhagen interpretation ('the measurement problem')
(2) the fact that any realistic solution to the classical/quamtum split must be nonlocal ('Bell test')
So the deep error is that Feynman, when commenting on the double slit "In this chapter we shall tackle immediately the basic element of the mysterious behavior in its most strange form. We choose to examine a phenomenon which is impossible, absolutely impossible, to explain in any classical way, and which has in it the heart of quantum mechanics. In reality, it contains the only mystery. We cannot make the mystery go away by “explaining” how it works. We will just tell you how it works. In telling you how it works we will have told you about the basic peculiarities of all quantum mechanics." was wrong in that the double slit is not the "only mystery", if it is a mystery at all. Rather it is the Bell test that encapsulates what we consider the mystery of quantum mechanics.
The Feynamn quote is from http://www.feynmanlectures.caltech.edu/III_01.html#Ch1-S8. Bolding above is mine. The Feynman lectures are of course superb, even though they have a few errors.
Here's Dr Chinese introduction to the Bell test, which I think Feynman should have presented, not the double slit. http://www.drchinese.com/Bells_Theorem.htm
Here is an excellent, but slightly technical introduction to the measurement problem. http://www.tau.ac.il/~quantum/Vaidman/IQM/BellAM.pdf
Another excellent, slightly less technical write-up on these issues. http://www.nature.com/news/physics-bell-s-theorem-still-reverberates-1.15435
I think another misleading quote from Feynman is "But, when one does not try to tell which way the electron goes, when there is nothing in the experiment to disturb the electrons, then one may not say that an electron goes either through hole 1 or hole 2. If one does say that, and starts to make any deductions from the statement, he will make errors in the analysis. This is the logical tightrope on which we must walk if we wish to describe nature successfully.". This is correct within the Copenhagen interpretation of quantum mechanics, which I certainly use. However, it can mislead one into thinking that it is necessarily true in all physical theories that explain the double slit. It is not true, for example, in Bohmian mechanics, which can successfully explain the double slit experiement with particles that have definite trajectories. http://scienceblogs.com/principles/2011/06/03/watching-photons-interfere-obs/
But before you go further in the foundations, may I suggest: learn how to do some actual quantum mechanical calculations in the Copenhagen interpretation. I haven't read all of these, but a quick glance seems to indicate that these are good introductions:
http://www.feynmanlectures.caltech.edu/III_toc.html (Feynman, of course, in spite of the occasional error)
http://arxiv.org/abs/1007.4184
http://www.youtube.com/playlist?list=PL84C10A9CB1D13841
http://ocw.mit.edu/courses/physics/8-04-quantum-physics-i-spring-2013/other/
Hi Matt, can you summarize for me here please? I am extremely confused by the claims made in youtube videos regarding the double-slit experiment.
Sorry Bahai. I am pretty confused as well. As a matter of fact... I have come to the conclusion that no one really knows wtf is going on when it comes to light unfortunately. If they do, I personally haven't met anyone who is able to communicate it well enough for my little brain to understand. Everyone seems to have an opinion on the matter and that makes it even worse.
I don't really buy the observer effect though any longer personally.
Forget them.
Here, using the QM formalism, is the proper answer:
http://arxiv.org/ftp/quant-ph/papers/0703/0703126.pdf
The issue is this stuff can be discussed at various levels of sophistication. At the lay level they are not quite correct - but it the best that can be done.
A much better analysis is the paper above. Note the heavy use of math. That's the issue here. This stuff is written in the language of math. If you want to avoid it you run into difficulties being exact.
But even that link has issues - a more careful analysis shows its not quite the truth either. And that is a big problem in physics - the real answers are often quite subtle, complex and use some really heavy math.
Thanks
Bill
They do - its described by QED.
But its a theory of the highly advanced math of Quantum Field Theory. I quote a guy who posts under the name of Streangerep in my signature - another thing he says - and its equally true - is one finds humility in field theory. It's HARD.
That said you may find the following dirt cheap lay treatment of it valuable:
https://www.amazon.com/dp/B004ULVG9O/?tag=pfamazon01-20
I have a copy and quite like it.
Feynmans well known book is also good:
https://www.amazon.com/dp/B00BR40XJ6/?tag=pfamazon01-20
But the issue you run into here is the varying levels of sophistication these things can be discussed at. At the lay level of sophistication it's not quite correct - but its the best that can be done. Feynman's book is not quite correct. This is really annoying - I know - but it's just the way it is.
Thanks
Bill
+1 to bhobba's comments. In fact, we've had a very good handle on what light does for pretty close to 100 years now. QED is just hard to explain in laypersons terms. Light is easy compared to a lot of problems in physics.
The fact that the (science interested) general public still thinks that "wave-particle duality" is a problem tells us something fairly troubling about science communication. To (poorly) paraphrase Sean Carrol - "Subtatomic particles aren't waves or particles, they're fields".
Indeed. QM is simply an approximation to QFT.
That's the view of the Colour Of Fields book I linked to. It tries to get that across in lay terms.
A different approach I rather like since it avoids many pitfalls.
Thanks
Bill
Thanks for the recomendation. I should check it out, my lay-person explanation of QFT is more like a third-year-undergraduate-physics-student explanation, which is rather unsatisfying for anyone without several years of university physics.
I think one confusing thing in this thread is that I, bhobba and Nugatory have agreed that the different results for single and double slit experiments are not puzzling, since different experiments give different results, and that the main complaint about the term "messing up" is that it could be misleading. On the other hand DrChinese has insisted that "messing up" is plain wrong, as indeed Feynman himself suggested.
Is the difference between whether contextuality or non-contextuality is adopted? So if we adopt non-contextuality, then we would say the detector is not messing up, and there is quantum weirdness. But if we allow contextuality, then we would say that the detector is "messing up" the interference, and there is no quantum weirdness. ?
I wouldn't get too worried.
Its just semantics and different interpretations of such - semantics would have to be one of the silliest things ever to get too worried about.
Thanks
Bill
If you are third year undergraduate level in math and/or physics the following would be a better choice:
https://www.amazon.com/dp/0691140340/?tag=pfamazon01-20
Its slow going, and you learn more with each reading - but it is the real deal.
Thanks
Bill
Thanks
Bill
I'm actually a physics PhD student. It's just that my explanation of QED is targeted at about a 3rd year level. (Which may indicate I don't understand it enough since I can't explain it to my grandmother. But that's ok, I'm an experimentalist ;) .) I like to read other peoples lay-person explanations, it helps make mine better.
Thanks
Bill
Or maybe QFT is an approximation to QM :) http://arxiv.org/abs/hep-lat/0211036 suggests that even QM can get g-2 in principle.
Thanks
Bill
Good to know.
Yea - my background is applied math - which labels me as a theorist I am afraid - not really into experimental stuff. My typical reaction and inclination is what some guy wrote about Landau - Mechanics:
https://www.amazon.com/dp/0750628960/?tag=pfamazon01-20
BTW love your picture of the great Emily Noether - deep respect.
If anyone doesn't know of her, and her famous Noether's Theorem - do check it out.
Thanks
Bill
Thanks
Bill
Good eye! I think Noether's theorem is absolutely the most beautiful result in theoretical physics. Noether herself is so fantastic. Even for a mathematitian :wink:.
So do I.
As I said deep respect for both her and her work.
As well as the discusting way she was treated that led Hilbert to say 'After all, we are a university, not a bath house'
Thanks
Bill
No, neither hole is blocked. The total amount of light passing through remains unchanged if the source is suitably situated.
This is a complete misconception. The knowledge of light is extensive and what you have read does not even begin to scratch the surface. The reason it is difficult to communicate is because there are so many situations in which subtle changes in the setup leads to different outcomes. Once it is agreed what the setup actually is, the scientific prediction can be determined.
@DrChinese, if I understand correctly, the basic intuition that mattjfox has is that different experiments have different results. The experiment with two polarizers vertical, and the experiment with one polarizer vertical and one polarizer horizontal, are different experiments. So why should we expect them to give the same interference pattern?
You are right, that part is fine.
But in my example, there is still the same "detector" mechanism in place regardless of the polarizer settings themselves. Note the title of the thread: "The detector itself contaminating double slit? How do we know?" So we do know!
And the answer is: It is NOT the detector's presence itself changing the outcome. It is ONLY the relative setting of the polarizers.
How's these: ?
In the case where the detector is placed at one of the slits, the detector is changing the interference pattern (compared to the setup without the detector).
More generally, an experiment with a different operation on the system (whether it is [STRIKE]unitary like[/STRIKE] a polarizer, or non-unitary like a detector) would change the interference pattern (compared to the setup without the operation).
This is not puzzling in general because we do expect different operations to have different results.
If there is a mystery in quantum mechanics, a Bell test expresses it better than the double slit, because the Bell tests prove that any realistic hidden variables cannot be local.
Edit: Not sure if a polarizer is unitary, it looks like a projector, see references in post #68.
atyy said:
How's these: ?
The only "detector(s)" in my setup are the polarizers in front of each slit. Nothing is added or removed. Let's assume the source polarization is at 0 degrees. When the polarizers are aligned parallel (both at 45 degrees) there is interference. If one of the polarizers is changed to -45 degrees, there is no interference. Intensity does not change in this example.
The only thing that changes is that when we have the *possibility* of determining which-slit information, interference disappears. Note that in actuality, nothing at all is detected. Yes, the different angle settings lead to different setups and therefore different results. But it is NOT because a detector is "contaminating" the double slit!
Sure, but one can also set it up with a detector. In that case, the detector is messing up the interference pattern.
In the OP's sense, sure. But that is obviously not the general case. Generally, the detector is NOT the cause and that is what I wanted to make clear.
My case is the general case, and that makes it clear that there is something else at work. The OP is on the wrong track.
