-- The drawing shows three particles far away from....
The discussion focuses on calculating the net gravitational force acting on three particles with masses mA = 340 kg, mB = 567 kg, and mC = 139 kg, positioned on a straight line. The calculations for particle A yielded a force of approximately 5.70 E-5 N, with suggestions to include proper units and consider significant figures. Users encountered issues with the Wiley Plus homework program, which flagged their answers as incorrect despite correct calculations. The importance of rounding and unit notation was emphasized throughout the conversation.
  • Understanding of Newton's Law of Universal Gravitation
  • Familiarity with gravitational force calculations
  • Knowledge of significant figures in scientific calculations
  • Experience with using online homework systems like Wiley Plus
  • Review Newton's Law of Universal Gravitation and its applications
  • Practice calculating gravitational forces between multiple masses
  • Learn about significant figures and their importance in physics calculations
  • Explore troubleshooting techniques for online homework platforms like Wiley Plus
Students studying physics, particularly those working on gravitational force problems, and anyone using online homework systems for physics assignments.
Clare
Member advised to use the formatting template for all homework help requests
The drawing shows three particles far away from any other objects and located on a straight line. The masses of these particles are mA = 340 kg, mB = 567 kg, and mC = 139 kg. Take the positive direction to be to the right. Find the net gravitational force, including sign, acting on (a) particle A, (b) particle B, and (c) particle C.
a. (6.67*10^-11*340*567)/0.5^2 + (6.67*10^-11*340*139)/0.75^2 = 5.70 E-5
After getting this one wrong i tried to adjust it with a negative sign in the front of the first set but to no avail. I don't even know how to go about any of the three parts because I keep confusing myslef with the same wrong answers.
I agree with your answer to (a). I don't have a calculator handy and did the arithmetic by hand, but if it is not the right answer, perhaps the right answer is 5.71 E-5. If it is a computerized program that is determining correct or incorrect, it should give you a little margin for error. I could have also miscalculated, but I believe my answer is correct. Try putting a "+" sign into your posted answer. ## \\ ## Edit: Perhaps you need to put "Newtons" or "N " or "Nt" in your answer. Without the units it really is incorrect.
How do you know that what you calculated is wrong?
It’s a homework program called Wiley Plus and this is the most trouble I’ve had with it
Did you try my suggestions?
Did you enter the units, as Charles Link pointed out in post # 2, and did you take care of the significant figures in your answer?
I did! apparently it just wanted me to round up even though you shouldn't and the units were already marked correct. The only one i haven't gotten is part c.
Thank you! I got it.
  • · Replies 40 ·
9K
27K
