-- The drawing shows three particles far away from....
The discussion revolves around calculating the net gravitational forces acting on three particles arranged in a straight line, with specific masses provided. The participants are attempting to solve the problem using gravitational force equations, while also addressing issues related to accuracy and formatting in a homework program.
  • Participants are discussing their calculations for the gravitational forces on each particle, questioning the correctness of their answers, and exploring the impact of significant figures and units on their submissions.
There is an ongoing exploration of the calculations, with some participants offering suggestions for adjustments and clarifications regarding units and rounding. While some participants express confidence in their answers, others are still uncertain about their results and the requirements of the homework program.
Participants mention the use of a specific homework program, Wiley Plus, which appears to have strict requirements for answers, including the need for units and consideration of significant figures. There is also a noted frustration with the program's feedback on their calculations.
Clare
Member advised to use the formatting template for all homework help requests
The drawing shows three particles far away from any other objects and located on a straight line. The masses of these particles are mA = 340 kg, mB = 567 kg, and mC = 139 kg. Take the positive direction to be to the right. Find the net gravitational force, including sign, acting on (a) particle A, (b) particle B, and (c) particle C.
a. (6.67*10^-11*340*567)/0.5^2 + (6.67*10^-11*340*139)/0.75^2 = 5.70 E-5
After getting this one wrong i tried to adjust it with a negative sign in the front of the first set but to no avail. I don't even know how to go about any of the three parts because I keep confusing myslef with the same wrong answers.
I agree with your answer to (a). I don't have a calculator handy and did the arithmetic by hand, but if it is not the right answer, perhaps the right answer is 5.71 E-5. If it is a computerized program that is determining correct or incorrect, it should give you a little margin for error. I could have also miscalculated, but I believe my answer is correct. Try putting a "+" sign into your posted answer. ## \\ ## Edit: Perhaps you need to put "Newtons" or "N " or "Nt" in your answer. Without the units it really is incorrect.
How do you know that what you calculated is wrong?
It’s a homework program called Wiley Plus and this is the most trouble I’ve had with it
Did you try my suggestions?
Did you enter the units, as Charles Link pointed out in post # 2, and did you take care of the significant figures in your answer?
I did! apparently it just wanted me to round up even though you shouldn't and the units were already marked correct. The only one i haven't gotten is part c.
Thank you! I got it.
  • · Replies 40 ·
9K
27K
