The efficiency of a transformer
5 replies · 3K views
Asmaa Mohammad
A step-down transformer has an efficiency of 90%, the voltage of it primary coil is 200V and its current is 0.5A, and its secondary coil has a voltage of 9V and a current of 10A and its number of turns is 90 turns.
Calculate the number of turns of the primary coil.
η =VsIs/VpIp * 100
Vs/Vp = Ns/Np
Is/Ip = Np/Ns
I solved the problem in two slightly different methods, the first one:
And the second one:
The solution in the first method (Np = 1800) is the correct one, but I don't understand why the second one is wrong. I thought that both will lead me to the same answer, but apparently they didn't, could you explain it for me, please?
The transformer is not ideal.
Hence,
Asmaa Mohammad said:
Vs/Vp = Ns/Np
this is not true.
Hence,
this is not true.
OK, but why (Is/Ip = Np/Ns) is true?
It is because of the mmf balance in the core. (Magetizing current is neglected as it is very small compared to the load current).
I didn't know about the MMF balance in my textbook, but I googled it and understood it. Many thanks!:smile:
Good!
Many thanks!:smile:
Thank google:wink:!
