The Eigenfunction of a 2-electron system
The discussion revolves around demonstrating that the wave function of a two-electron system is an eigenfunction of the Hamiltonian when the electrons do not interact. The user is struggling with the calculations, particularly in substituting the two-electron wave function into the Hamiltonian and confirming that the energy is constant and independent of the radial coordinate. Despite knowing that Z = 2, the user is unable to derive the expected energy value, indicating a potential misstep in factoring out the kinetic energy term. A suggestion from another participant ultimately helps the user resolve the issue. The conversation highlights the importance of correctly applying the Hamiltonian to multi-electron systems in quantum mechanics.
Settho
Show that the wave function is an eigenfunction of the hamiltonian.
Hamiltonian, wave function, energy and Born radius
Hello!
I am stuck at the following question:
Show that the wave function is an eigenfunction of the Hamiltonian if the two electrons do not interact, where the Hamiltonian is given as;
the wave function and given as;
and the energy and Born radius are given as:
and I used this for ∇ squared:
I am stuck at the end of the calculation. I know Z = 2, but somehow I don't end up with the energy, which you need to show that it is indeed an eigenfunction. This is what I get and where I am stuck at:
and even when I substitute a0 in this formula, I don't get the energy value. I honestly don't know where it did go wrong.
If someone is able to help, that would be great.
You need to substitute the two-electron wavefunction$$\psi(r_1,r_2)=\psi(r_1)\psi(r_2)=\frac{1}{\sqrt{\pi}}\left( \frac{Z}{a_0}\right)^{3/2}e^{-\frac{Z}{a_0}r_1}\frac{1}{\sqrt{\pi}}\left( \frac{Z}{a_0}\right)^{3/2}e^{-\frac{Z}{a_0}r_2}$$in your Hamiltonian. The energy is a constant and should have no ##r## dependence.
But isn't it just the idea to split the Hamiltonian in electron 1 and electron 2 instead of the two-electron wave function?
The ##-\hbar^2 / 2m## term doesn't factor out of all terms.
Your simple suggestion made me solve the problem. Thank you so much!
