What is the electric field strength at point P in this charge configuration?
The electric field strength at point P, located on the y-axis 0.61 m from the origin, is calculated to be 1.613 x 10^5 N/C at an angle of 77.979 degrees. This configuration involves two charges: q1 = +8.15 µC at the origin and q2 = -3.70 µC positioned 0.52 m along the x-axis. The calculations utilize the formula E = kQ/r^2, with k = 9.0 x 10^9, and involve vector addition to determine the resultant electric field components.
  • Understanding of electric field concepts and vector addition
  • Familiarity with Coulomb's Law and the constant k = 9.0 x 10^9 N·m²/C²
  • Proficiency in trigonometry, specifically sine and cosine functions
  • Ability to apply the Pythagorean theorem in two-dimensional vector analysis
  • Study the derivation and applications of Coulomb's Law in electrostatics
  • Learn about vector addition of forces and fields in physics
  • Explore the use of trigonometric identities in calculating angles between vectors
  • Investigate the concept of electric field lines and their representation in charge configurations
Students in physics, particularly those studying electromagnetism, as well as educators and anyone seeking to deepen their understanding of electric fields and vector analysis in charge configurations.
FSNxPhantom
A charge q1 = +8.15 muC is at the origin, and a charge q2 = -3.70 muC is on the x-axis 0.52 m from the origin. Find the electric field strength at point P, which is on the y-axis 0.61 m from the origin.
Answer = [1.613 x 10^5 N/C at 77.979 degrees]
E = kQ/r^2
k = 9.0 x 10^9
tan o = Ey / Ex (?)
C^2 = A^2 + B^2 (?)
Ex = E1 cos 30 (?)
Ey = E2 - E1 sin 30 (?)
I used the Pythagorean Theorem to figure out the distance from P to q2, which gave me 0.8 m.
I then went to use E to find E1, which I inputted as
((9x10^9)x(3.7x10^-6))/(0.8^2) = 5.2 x 10^4 N/C
Then E2 as
((9x10^9)x(8.15x10^-6))/(0.61^2) = 2.0 x 10^5 N/C
From there:
Ex = E1 x cos 30 = 4.5 x 10^4 N/C
Ey = (E2 - E1) x sin 30 = 7.4 x 10^4 N/C
Then I used Pythagorean Theorem again, thus getting:
E = Square root (4.5^2 + 7.4^2) x 10^4 = 8.7 x 10^4 N/C
Where did I go wrong? or did I do it incorrectly?
FSNxPhantom said:
From there:
I don't know where that "cos 30" came from, but you could simply add the vectors E1 and E2.
If a and b are two vectors with an angle C between them, then their sum, c can be calculated with this formula:
c^2=a^2+b^2-2abcosC
When i used that, I put in:
c^2 = (5.2 x 10^4)^2 + (2.0 x 10^5) - (2 x (5.2 x 10^4) x (2.0 x 10^5) x (cos 49.46)) = 1.7 x 10^5
I found 49.46 by:
Cos-1 (.52/.8) = 49.46
Still confused since it was wrong. Did i do it wrong? And if so, how do i found the angle for it being the answer:
I found 49.46 by:
Take in account that the E field generated by a positive charge points away from it and the E field generated by a negative charge points towards it. Make a drawing and see what is the angle between E1 and E2, considering their directions.
P
l\
l..\
l...\
l...\
l_____\
q1->...<-q2
Is this it? Because I missed the class lesson and have to figure it all out right now.
And sorry for the bother since I'm clueless right now.
FSNxPhantom said:
P
l\
l..\
l...\
l...\
l_____\
q1->...<-q2
You need to represent the E field in the point P, so draw E1 and E2 at P.
SOOOo...
E2______E
l.../
l.../
l.../
l.../
l.../
l./
l/\ Angle
P_\_______
l\ E1./
l..\./ Angle from Cos o = (.52/.8) (?)
l...\
l...\
l...\
q1->..<-q2
Where the magnitude of E1 = 5.2 x 10^4 N/C and E2 = 2.0 x 10^5
Am I doing it right so far?
You represented correctly E1 and E2. E1 as you calculated it is the field generated by q2 and E2 is the field generated by q1, at point P.
You didn't take the right angle though. You need the angle between E1 and E2.
E2______E
l.../
l.../
l.../
l.../
l.../
l./
l/\ Angle = o1 + o2 = 90
P_\_______
l\ E1./
l...\
l...\
l...\
q1->..<-q2
And the angle between E1 and E2 is:
o = Cos^-1(.52/.8) + 90 degrees (from E2 to line in middle) ?
And for Ex and Ey (if there is)
Ex = E1 cos 49.46
Ey = E2 - E1 sin 49.46
Yes. So the angle is 90 + arccos(0.52/0.80).
Now apply the formula that I gave you and, if the calculations are right you should get the right result for the magnitude of the E field at point P. You don't need Ex and Ey.
Angle is 90 + arccos(0.52/0.80) = 139.46
Then: a = (5.2 x 10^4) b = (2.0 x 10^5)
c^2 = a^2 + b^2 - 2abcos(139.46) = 2.4 x 10^5
c^2 = a^2 + b^2 + 2abcos(139.46) = 1.64 x 10^5 (close enough lol)
So how do I find the second part to the answer? [77.979 degrees]
To find the angle you must know one component of E, either Ex or Ey. Since to the component of E in the x direction only E1 has a contribution, it means that Ex is easier to get. So calculate the component of E1 in the x direction, E1x. This will be equal to Ex. Then, knowing Ex and E you can find the angle between them, right?
Ex = E1 cos (49.46) = 3.38 x 10^4
E = 1.64 x 10^ 5
So:
Angle = arccos (Ex/E) = 78.1 degrees
E = 1.64 x 10^ 5
So:
Pretty close. There must be some approximations differences between your calculations and their.
BTW that formula, indeed should have been with a + . My mistake.
Thank you for your help. I'll see what my professor did to get that answer.
