How to Calculate the Coefficient of Friction on a 20 Degree Incline?
  • Thread starter Thread starter emonroe14
    Force
This discussion focuses on calculating the coefficient of friction for a car on a 20-degree incline. The car's weight is 1392.7 kg, and its acceleration is determined to be 4.62 m/s². The force required to move the car is calculated as 646.49 N. To find the coefficient of friction (Cf), the relationship between the normal force and the frictional force is established, emphasizing the need to account for the incline's angle in the calculations.
  • Understanding of Newton's laws of motion
  • Knowledge of basic trigonometry for inclined planes
  • Familiarity with the concept of force and mass
  • Ability to perform calculations involving acceleration and friction
  • Learn how to apply trigonometric functions to resolve forces on inclined planes
  • Study the relationship between normal force and frictional force in detail
  • Explore advanced topics in dynamics, such as friction coefficients for different materials
  • Investigate the effects of incline angles on vehicle performance and safety
Students in physics or engineering courses, automotive engineers, and anyone interested in understanding vehicle dynamics on inclined surfaces.
emonroe14
Pick a car, find its acceleration. calculate the force necessary to move the car with this acceleration and the minimum coefficient of friction to accomplish this. repeat the calculation of the coefficient of friction on a 20 degree incline.
How do i calculate the coefficient of friction? on a 20 degree incline as well?
0-60= 5.8s
weight=1392.7kg
acceleration= change in velocity/ change in time
acceleration= 26.82m/s / 5.8s = 4.62 m/s2
weight= massx acceleration of gravity
1392.7= m(9.81 m/s2)
mass= 141.97
force= mass x acceleration
F= 141.97x 4.62 m/s2
F= 646.49 N
How do i find coefficient of friction and the coefficient of friction on a 20 degree incline?
Since you have the amount of force on the plane, you can take that and set it equal to the force of friction.
646.49 = m* g * Cf (Coefficient of Friction, since keyboards don't have mew), divide the mass and g off and you have the coefficient of friction
Hi emonroe14, welcome to PF.
Post the complete text of the problem.
Friction is always parallel to a surface and is figured by the component of force normal to the surface.
The CF is a ratio between the normal force and the force of friction it generates. It varies with surfaces (including the tires).
On a flat surface the normal force is typically the mass times the acceleration of gravity. But when the surface is tilted, the force of gravity is still straight down, while the force causing the friction is perpendicular to the surface. (Think of using some trig here.)
The friction force must be greater than the force of acceleration, so that sets the lower limit.
  • · Replies 19 ·
