The Friedmann equation in a lambda-dominated universe
4 replies · 4K views · last reply
_Andreas
Show that a lambda-dominated euclidean universe entails an exponential expansion.
Equation of state is P=-E (E=epsilon)
There is no curvature (i.e. a flat universe)
The Friedmann equation is then
((a(dot)/a)^2)=((8piG)/3c^2)E + lambda/3 (eq. 1)
which -- and this is where I get lost -- is equivalent to
((a(dot)/a)^2)=((8piG)/3c^2)Elambda (eq. 2)
lambda/3 = ((8piG)/3c^2)Elambda, but if I make this substitution into the Friedmann equation, I get
((a(dot)/a)^2)=((8piG)/3c^2)E + ((8piG)/3c^2)Elambda
What am I doing wrong? I'm after (eq. 2).
You have two different representations of the same thing in the Friedmann equation. A constant term lambda is the same thing as a vacuum energy source term satisfying rho=-p. Which one do you want to work with? You don't need both.
I'm not sure I understand. Could you elaborate further?
What part don't you understand? A fluid with E=-p satisfies dE/dt=0 by the conservation equation, so is a constant. lambda is also a constant. You have two constants. It's a little redundant.
I just wanted to say thank you for your efforts, Dick. They're appreciated. I forgot to say that. Sorry!
