The g_ij as potentials for the gravitational field
The discussion centers on the analogy between gravitational potentials represented by the metric tensor components \( g_{ij} \) and electromagnetic potentials represented by the vector potential \( A \). The Christoffel symbols \( \Gamma_{ijk} \) are compared to forces in motion equations, but it is established that they are not tensors and do not behave like forces. The Einstein tensor \( G \) is identified as the gravitational analogue to the electromagnetic field tensor \( F \), obeying field equations similar to Maxwell's Equations. The conversation also touches on gauge invariance and the role of curvature in general relativity.
  • Understanding of general relativity concepts, specifically the Einstein tensor \( G \) and Christoffel symbols \( \Gamma_{ijk} \).
  • Familiarity with electromagnetic theory, particularly Maxwell's Equations and the field tensor \( F \).
  • Knowledge of differential geometry, including metrics and curvature tensors.
  • Basic grasp of gauge invariance and its implications in physics.
  • Study the Einstein tensor \( G \) and its derivation from the Riemann curvature tensor.
  • Explore the concept of gauge invariance in both electromagnetism and general relativity.
  • Investigate the implications of linearized gravity and its relationship to gauge theories.
  • Examine the mathematical framework of differential geometry as it applies to general relativity.
This discussion is beneficial for theoretical physicists, mathematicians specializing in differential geometry, and students of general relativity seeking to understand the analogies between gravitational and electromagnetic fields.
dx
TL;DR
invitation to discuss general covariance
The equation of motion for a particle in a gravitational field is
ai = -Γijk vj vk
In inertial coordinates the Lorentz force is
mai = qFij vk
So it seems like F corresponds to Γ. Just like F is expressed in terms of the derivatives of A, the christoffel symbols are expressed in terms of derivatives of gij:
Γijk = 1/2 gli [ gil,k + gkl,i - gil,l ]
Fij = gli [ Aj,l - Al,j ]
So apparently gij are the gravitational potentials just like A is the electromagnetic potential. What is the precise form of this analogy? What is the analogue of the gauge invariance under A → A + dχ? Is it general covariance? And where does Rijkl fit into all of this?
No, it doesn't. The Christoffel symbols are not tensors. The tensor in GR that corresponds to F in electromagnetism, at least if you're looking at field equations and equations of motion, is the Einstein tensor G. (Note that this tensor is the contracted double dual of the Riemann tensor, which answers your question about how the Riemann tensor comes into all this.) G is the tensor that obeys a field equation analogous to Maxwell's Equations, which connects the field with the source (the stress-energy tensor T, which is the analogue of the Maxwell 4-current J) and imposes automatic conservation of the source (covariant divergence equals zero) because the field tensor obeys the necessary identities.
In some ways this is a workable analogy, but in other ways it isn't. For example, as noted above, the first derivatives of the metric g cannot be used to form a tensor that obeys a field equation; you have to go to the second derivatives.
Also, when you start looking at gauge invariance, which you also asked about, it turns out that the connection coefficients act like potentials, and the curvature acts like the field. From this viewpoint, the electromagnetic potential A is a connection on an appropriate fiber bundle (a U(1) bundle), and F = dA is the corresponding curvature. In this analogy, A is analogous to the Christoffel symbols, and F is analogous to the Riemann tensor, which is the curvature derived from the connection defined by the Christoffel symbols. Gauge invariance arises in both cases because there is not one unique connection, but a whole equivalence class of connections, that all give rise to the same curvature.
love_42 said:
Summary:: invitation to discuss general covariance
ai = -Γijk vj vk
mai = qFij vk
Christoffel symbols are somewhat similar to forces, as they look a little bit like forces in the equations of motion as you point out, but they aren't exactly identical to forces. As others have mentioned, they transform differently - and not as tensors. There are only 3 components in a 3-force, 4 if you generalize to a 4-force. There are 40 Christoffel symbols by my count (taking into account the symmetry of the last two indices in the assued absence of torsion), a lot more components than forces have.
I'm not sure of the precise form of the analogy, but certainly for linearized gravity, the metric coefficients play the role of potentials. And for linearized graity, a change of gauge is represented by a coordinate change, a diffeomorphism, that leaves the perturbed metric ##h_{uv}## small. See for instance https://en.wikipedia.org/w/index.php?title=Linearized_gravity&oldid=982540808#Gauge_invariance
I'm not sure of the status of the analogy in the strong field. GR isn't linear in strong fields, so I think that would limit the applicability of any analogy.
This is true, but they are still linear operators like tensors. The difference comes from the way they are defined. The tensor F is a geometric coordinate independent object like a vector, which has different components depending on the coordinates used to define the components. The affine connection's components on the other hand describe how the coordinate system is twisting and turning from point to point (imagine the present remarks in the context of a flat space with various nonlinear coordinates for definiteness and clarity.) This is not entirely unexpected, since a change of coordinate system in general relativity is equivalent to a change in the gravitational force field, e.g. an inertial frame free of forces is equivalent to an accelerated frame which can be thought of as an inertial frame filled with a uniform gravitational force field. I am talking about forces rather than using the word 'field' to be as unambiguous as possible, since for the purpose of this discussion we want to leave open the question of which symbol corresponds to the curvature, connection, potential, field etc. I believe the central issue, which Einstein emphasizes again and again is the following: Every observation or measurement ultimately rests on the coincidence of two independent events at the same space-time point. The introduction of a system of reference serves no other purpose than to facilitate the description of the totality of such coincidences. Imagine a measuring stick which measures the height of a man. Now a smooth deformation or diffeomorphism will not change the point where the head of the man meets the measuring stick, since both are deformed by the diffeomorphism.
Also, I would like to say that what I am after in this thread is not the details of the analogy (and it may not be an 'analogy' at all in the sense of a precise duality where objects on one side correspond to an analogous object on the other side. It could be more like a 'deformation') Anyway, what I am after is the significance of the diffemorphism invariance.
I believe you are mistaken here. F, which has 16 components, is not the force. However, eFtx = eEx is the electric force in the x direction. Like I said above, imagine the present remarks in the context of a flat Minkowski spacetime with various nonlinear coordinates for the purpose of simplicity. We easily see in this context that the numbers -mΓijk are indeed forces. They are simply the fictitious forces introduced by the non-inertial coordinates.
Mathematically I'd say in electromagnetism the gauge field ##A_{\mu}## is defining the gauge-covariant derivative, i.e., it's a connection (on a fiber bundle) and thus it's analogous to the Christoffel symbols in GR, defining the connection on the corresponding pseudo-Riemannian manifold.
From this point of view the Faraday tensor ##F_{\mu \nu}## is connected with the commutator of gauge-covariant derivatives and thus a curvature tensor on the fiber bundle. That makes it analogous to the pseudo-Riemannian curvature tensor in GR.
I think you need a few more qualifiers here - but if you have an orthonormal basis ##\hat{t}, \hat{x}, \hat{y}, \hat{z}## and a stationary test charge, one of the components of F does turn out to be equal to the force.
In general, though, you need to write ##e F^{ab} u_b##, where ##u_b## is the 4-velocity of the test charge. When the test charge is stationary, and ##g_{00}## is unity, ##u_b## has components (1,0,0,0). If ##g_{00}## is not unity or the charge is moving, ##u_b## won't have compnents (1,0,0,0).
And of course if the test charge is moving, you have contributions from the components of the Faraday tensor F which represent the magnetic fields to the forces.
Specific components of the Christoffel symbols in an orthonormal basis, namely ##\Gamma^{\hat{x}}{}_{\hat{t}\hat{t}}, \Gamma^{\hat{y}}{}_{\hat{t}\hat{t}}, \Gamma^{\hat{z}}{}_{\hat{t}\hat{t}}## representing some a specific frame are formally similar to forces in that frame.
However, calling this particular subset of the Christoffel symbols forces is a bit risky , because the transformation laws for the Christoffel symbols are generally different. If you stick to one set of coordinates and/or basis vectors, it can be useful to pick some particular frame and it's corresponding basis vectors , compute the above symbols, and get some physical insight. But if one wishes to use multiple or general frames, one has to be more careful.
To give a specific example, one of the predictions of GR is the deflection of light being doubled from a Newtonian-like prediction. Interpreting this extra deflection as due to a doubling of the "force" is problematical.
It's not a doubling of the force but the fact that it's the curvature of spacetime not only space that's relevant for the geodesics. Einstein's result of 1912 was indeed wrong, because he had not yet the full equations of GR at hand at this time. In this sense it's somewhat lucky that the light-bending measurement couldn't be done by Fröhlich in 1914, because then he'd found out that Einstein was wrong by a factor 2 in his prediction of the bending! So it was a great success in 1919 when Einstein's then of course correct prediction of the amount of light bending was confirmed by Eddington et al.
The fact that ub doesn't have components (1, 0, 0, 0) does not seem to be relevant to me. Maybe I am misunderstanding your point, but the schematic form of F
F =
\begin{pmatrix}
\mathrm{0} & \mathrm{-E} \\
\mathrm{E} & \mathrm{B}
\end{pmatrix}
*F =
\begin{pmatrix}
\mathrm{0} & \mathrm{*B} \\
\mathrm{-*B} & \mathrm{*E}
\end{pmatrix}
retains its meaning independently of coordinates. Here E is a 1-form and B is a 2-form. In terms of these forms, for example ∇⋅E = 1/ε0 ρ becomes
$$-*\mathrm{d*E} = \frac{1}{\epsilon_0} \rho$$
Could you explain this in a little more detail? A gravitational general relativistic effect can always be interpreted as the result of fictitious forces, because fictitious forces cannot be distinguished from gravitational fields.
re: the doubling of the deflection of light
I'd agree. A detailed calculation of the deflection of light can in my opinion shed some light on the limitations on the "force" paradigm, and why we often say that gravity is not a force. I actually suspect it's possible for a sufficiently determined person who is very attached to the idea of forces to "patch up" the force paradigm to handle light, but it's pretty clear that the the analogy to the coulomb force fails to explain the extra deflection, and the analogy to the magnetic force in this case also yields no extra deflection.
The conventional explanation of the extra deflection of light doesn't involve any extra forces, but as you say, the curvature of space, with a particular conventional choice of the space-time split.
So it's not a "force" that deflects light - but spatial curvature.
Actually, no part of the usual calculations of the deflection of light use the idea of forces at all, as far as I know. So the usual calculations (for instance using PPN, though one can use more exact schemes as well) also illustrates that one doesn't actually need forces to calculate "stuff".
To even attempt to apply forces at all, one would probably want to consider the deflection of rapidly moving particles, and calculate the deflection of the particles as a function of velocity. Then one could take the limit as the velocity of the particles approached "c". I believe one would still conclude that spatial curvature, rather than force, was the best explanation of the extra deflection of rapidly moving particles.
F =
\begin{pmatrix}
\end{pmatrix}
*F =
\begin{pmatrix}
\end{pmatrix}
Well, rather than attempt a lengthly exposition, I'll suggest considering what F looks like in cylindrical coordiantes, ##t, r, \theta, z##. What you should eventually conclude is that the components of F do not follow your simple schema.
The basic point I'm making is that tensors are expressed in terms of basis vectors. Basis vectors are not coordinates, but there is a set of basis vectors, called a coordinate basis, that is associated with a specific choice of coordinates.
Additionally, an important sub-point is that coordinate basis vectors don't necessarily have unit length. For instance, for the line element ##dr^2 + r^2 d\theta^2##, the coordinate basis vector with components (0,1), usually dentoed as ##\partial / \partial \theta##, has a length of "r", not a length of 1.
So the point I'm making is to consider F in cylindrical coordinates, once with the coordinate basis vectors, usually denoted as ##\partial / \partial r, \partial / \partial \theta##, with the length of ##\partial / \partial \theta## being "r" and not unity. Additionally, you can if you chose use cylindrical coordianates, but not use coordinate basis vectors, but the unit basis vectors ##\hat{r}, \hat{\theta}##, with ##\hat{\theta} = (1/r) \partial / \partial \theta##. You'll probably not find an easy textbook explanation of how to calculate the Christoffel symbols in a non-coordinate basis, though. If you do, please share :).
You can't readily explain gravitational time dilation in terms of forces, nor can you readily explain spatial curvature in terms of forces. But tensors and the associated Christoffel symbols can explain both.
To give another specific example, look at the behavior of "forces" in Einstein's elevator, ideally using tensors and Christoffel symbols. It's a flat space-time problem, no curvavture is needed. So it won't address the curavture issue, but it will address the time dilation issue. You'll see that you have some Christoffel symbols that repreent your force, but you'll have some additional Christoffel symbols related to time dilation and not to forces.
The metric for Einstein's elevator is the well-known Rindler metric, which has many forms. One of the most concise is
$$ds^2 = -a^2 z^2 dt^2 + dx^2 + dy^2 + dz^2$$
however, the conciseness comes at the expense of the origin of the coordinate system being displaced.
No, they aren't. Tensors are linear operators on the tangent space at a particular event. Connection coefficients are maps from vectors in the tangent space at one event to vectors in the tangent space at other nearby events, along a particular curve. These are very different things.
No, it doesn't. The tensor F is an antisymmetric 2nd-rank tensor, and so has only 6 independent components. These are easily interpreted, in a particular frame, as the components of the electric and magnetic force field vectors in that frame.
You can adopt a similar interpretation locally in curved spacetime. For example, if you set up Fermi normal coordinates centered on a particular object's worldline, with spatial axes fixed to the object, then there will be acceleration and rotation terms in the metric that tell you about the non-inertial motion of the object, and these terms, in the equation of motion of a test object in these coordinates, will appear as "fictitious forces" like "acceleration due to gravity", "centrifugal acceleration", and "Coriolis acceleration".
However, this interpretation will not work globally in a curved spacetime; in general you can't interpret terms in the metric in some global coordinate chart, or the terms in the equation of motion of a test object that they give rise to, this way.
As above, such an interpretation will work locally in GR, but not globally. Locally, the effects of tidal gravity--spacetime curvature--can be ignored in a small enough region of spacetime, and then the equivalence principle, which is what you are stating here, applies. But globally, the effects of tidal gravity/spacetime curvature cannot be ignored, and the equivalence principle does not apply. For example, if you are allowed to make measurements over a large enough region of spacetime, you can tell the difference between accelerating at 1 g in a rocket in free space and sitting at rest on the surface of the Earth with 1 g acceleration, by measuring the presence of tidal gravity in the latter case and its absence in the former.
Since light bending by an object like the Sun is a global effect, not a local effect, it cannot be interpreted solely in terms of "fictitious forces"; the effects of spacetime curvature cannot be ignored. In the most convenient coordinates for doing the analysis, those effects appear as "space curvature" doubling the "Newtonian" deflection (which can be derived by a local analysis using the equivalence principle), as others have said.
  • Love
The equation
ai = -Γijk vj vk
is perfectly capable of explaining the deflection of light by the sun. The tensor
$$ R^i_{jkl} = \Gamma^i_{jk,l} - \Gamma^i_{jl,k} + \Gamma^m_{jk}\Gamma^i_{km} - \Gamma^m_{jl}\Gamma^m_{km}$$
and its geometric interpretation is of secondary importance to me. Obviously, Einstein needed the full field equations in order to calculate the appropriate Γijk with the appropriate curvature, but the geodesic equation ai = -Γijk vj vk is exactly valid as a description of light. It applies to massless particles also.
I want to say that what I am proposing as a topic of discussion in this thread is not a crackpot or unorthodox idea. I want to discuss the gauge invariance of the field equations and what it might mean. To quote Feynman,
Feynman said:
Consider an inertial reference frame on a flat Minkowski space. It makes no sense for us to claim that the choice of coordinates that someone else makes is crazy and cockeyed, just because it does not look like an inertial frame to us. If he insists on treating it as inertial, and ascribes curvature to the fields, he is perfectly justified in doing so, and it is our reference frame that looks cockeyed to him[...] The fact that a spin-two field has a geometrical interpretation is not really necessary or essential to physics. It might be that the whole coincidence might be understood as some kind of gauge invariance
Something a bit off topic. This made me think about the analogy, and I do realize that all analogies are limited, but is G the analog of F. From the field equations point of view, it seems to be the right choice. But in vacuum G is zero and F need not be. Wouldn't the Weyl tensor, at least for vacuum solutions, be the analogous to the Maxwell tensor?
love_42 said:
The equation
ai = -Γijk vj vk
No, it isn't. Integrating this equation as it stands over the global path of the light ray gives an answer for the amount of bending only half as large as the correct answer. (Note, btw, that this is not limited to light; if you try to compute the trajectory of a massive particle flying by the Sun at a speed close to the speed of light, you will have the same problem, the only difference will be that the factor by which your computed answer falls short of the correct answer will not quite be 2. The general form of the extra factor, in barycentric coordinates, is ##1 + v / c##, where ##v## is the coordinate velocity of the object.)
That's because the field equations aren't identical in the two cases. The Maxwell equation that relates F to the source J is ##\nabla_\mu F^{\mu \nu} = 4 \pi J^{\nu}##. But the Einstein field equation that relates G to the source T is ##G _{\mu \nu} = 8 \pi T_{\mu \nu}##. The latter is a simple equality, but the former is not, it's a differential equation, so it leaves room for F to not vanish even when J vanishes.
I suppose one could view it that way. However, I don't know if there's any way of splitting F up mathematically into a "Weyl" piece that can be nonzero in the absence of a source, and a "Ricci" or "Einstein" piece that must vanish in the absence of a source, the way one can with the Riemann tensor.
Einstein's calculation was wrong because he was using Newtonian potentials instead of appropriate relativistic fields.
This is from Rindler's book.
What "Einstein's calculation" are you referring to?
The one that was wrong by a factor of two.
Einstein made that calculation based on a previous version of his field equation that turned out not to be the right one, as @vanhees71 noted in post #8. When he found the final, correct version of his field equation, in 1915, he re-did the calculation and got the correct answer.
None of this changes the fact that your claim in post #14 is wrong, for the reason I gave in post #16.
In your post 16, you seem to be claiming that not only light, but also particles (with v ~ c) don't follow the geodesic equation. This is obviously wrong. The fact that light is described by the geodesic equations is standard textbook material as far as I know. If you want I can post the details of how that works, or give a reference. Anyway, there is no way Einstein could have calculated the deflection of light from the equivalence principle before he had the field equations. When people say that the factor of two came out wrong due to the fact that there is no global inertial frame, they are referring to the fact that application of the equivalence principle was only possible in uniform gravitational fields before the Einstein equation was discovered. This is why Einstein tried to use the Newtonian potential -GM/r, and got the factor of two wrong. Your comments about v ~ c particles are also probably connected with some approximation like this.
I was not making that claim. I was clarifying what "follow the geodesic equation" actually means. Integrating that equation globally involves aspects that do not appear if you only look at the equation in a single local inertial frame. Those aspects include the effects of the Riemann curvature tensor, which you appeared to be saying you could ignore. You can't just use the geodesic equation and ignore the curvature tensor if you are trying to compute a global answer. Possibly I misunderstood your remarks about the curvature tensor being "of secondary importance".
Agreed; calculating it from the equivalence principle gives an answer that is too small by a factor of 2.
I have seen no evidence that Einstein ever did this. His 1912 calculation, referred to previously, that got an answer too small by a factor of 2, was based on an earlier, incorrect version of the field equation, which turned out to give the same answer as you would get from the equivalence principle without using any field equation. It was not based on "using the Newtonian potential".
Okay. I agree you can't ignore the curvature tensor. By "secondary importance" I simply meant that I wanted to leave its geometrical interpretation as an open question for the purpose of this discussion of general covariance. I say we start with Einstein's point-coincidence argument. As I mentioned in one of my earlier posts, an active diffeomorphism of everything in spacetime does not change where a ruler meets the head of a man, so nothing measurable is affected by active diffeomorphisms. Einstein's equations are not only invariant under general coordinate transformations (passive diffeomorphisms) but also under active diffeomorphisms of the fields, so this is indeed some kind of gauge transformation of the fields, rather than just a coordinate change.
I haven't actually read the historical papers, but when I say "using the Newtonian potential", I was referring to the fact that time dilation in the gravitational field and such things can be calculated in terms of the gravitational potential. So a half-relativistic attempt at calculating the deflection can be made by taking these dilation effects into account. Using the Newtonian potential to calculate the time dilation and then trying to calculate the deflection does indeed result in an answer off by a factor of two.
So can the "space curvature" that provides the factor of 2 correction. The general weak field approximation to the metric that is applicable to this case is (in units where ##G = c = 1##):
ds^2 = - \left( 1 - \frac{2M}{r} \right) dt^2 + \left( 1 + \frac{2M}{r} \right) \left( dr^2 + r^2 d\Omega^2 \right)
As you can see, the "Newtonian potential" appears in both the time and space parts of the metric. The error in the earlier version of the field equation that Einstein used in 1912 was basically that that version did not give the ##1 + 2M / r## factor in front of the spatial part of the metric in this approximation; that was what caused the answer he got then to be a factor of 2 too small.
The analogue of F would be the field strength of the spin connection omega. It can be constructed from the [M,M] commutator of the Lorentz algebra.
Ok, that helps to clarify things.
There is a huge amount of literature on this, some of which has been discussed in previous PF threads, though it's been a while since we've had one.
I think the general takeaway from all those discussions is that, as you say, none of these transformations (either passive or active diffeomorphisms) change any actual physical observables, and that means there is room for a number of different viewpoints on what the transformations "mean", none of which can be tested against each other by experiment because all of the viewpoints agree on the results of all experimental tests. So it comes down to a matter of personal preference on how you want to describe what the transformations "mean".
But from a relativity standpoint, any such attempt should be immediately suspect, because "time" and "space" are frame-dependent, so if we are looking for a generally covariant expression, "time dilation" can't just be there on its own. There has to be some corresponding effect on the space part of the metric.
One way of describing the error in the 1912 version of the field equation that Einstein used for his earlier wrong calculation of Mercury's perihelion precession is that it failed to recognize the above point. Recognizing it forced Einstein to go back and rework the field equation until he found a fully generally covariant form for it, which in turn led to a weak field approximation that, as expected, included effects on both time and space, both proportional to the Newtonian potential, and which gave the correct result for the precession.
love_42 said:
The equation
ai = -Γijk vj vk
Agreed. But calculating the deflection requires, as others have said, is a more involved process than the shortcuts you are apparently taking.
One can calculate the deflection in Schwarzschild coordiantes, but it doesn't give as much insight into the cause as using PPN coordinates.
A bit of background. The PPN paramter ##\gamma## is described as:
\gamma How much space curvature ##g_{ij}## is produced by unit rest mass
There is another nonzero PPN paramter ##\beta## in GR, but it doesn't affect the deflection of light.
The details of the calculation can be found in MTW's (Misner, Thonre, Wheeler) "Gravitation", pg 1102, though you'll need to go to the earlier pages to get the PPN metric. Which is a bit involved, as PPN as described in MTW is used to accommodate any metric theory of gravity to allow a comparsion framework for multiple theories. However, GR has only two nonzero PPN paramters, ##\beta## and ##\gamma##, and I'll give the metric coefficients for those at the end of the post.
Using the geodesic equation, one can calculate the trajectory of the light path in the ##r, \phi## plane that light takes:
$$\frac{b}{r} = \sin \, \phi + \frac{\left( 1+\gamma \right) M}{b} \left( 1 - \cos \phi \right)$$
That's just from the textbook, if you don't trust the textbook, you'll probably have to wade through it on your own, but it should be possible by solving the geodesic equations.
b can be regarded as the "impact parameter". It is approximately the distance of closest approach, which is
$$r_{min} = b\left[ 1 - \frac{ (1 + \gamma) M}{b}\right]$$
This can be expanded in a series form around around ##\phi=0##, which will be regard as the ingoing ray, and around ##\phi=\pi##, which will be regard as the outgoing ray:
$$\frac{b}{r} = \phi + O(\theta^2) \quad \frac{b}{r} = \frac{2 \left(1+ \gamma \right) M}{b} + \left( \pi - \phi \right) + O((\pi - \phi)^2)$$
The end result is that the spatial curvature term ##\gamma=1## doubles the deflection of the light for small angles ##\phi## compared to a hypothetical deflection for a metric theory with no spatial curvature. An example of such a theory would be the Newtonian approximation to GR which has no spatial curvature. This approximation is also discussed in MTW.
The metric elements for the Newtonian approximation in geometric units where G=c=1 are:
$$g_{00} = -1 + 2U \quad g_{ij} = \delta_{ij}$$
The metric elements for the PPN approximation in geometric units are
$$g_{00} = -1 + 2U - 2\beta U^2 \quad g_{ij} = \delta_{ij}(1+2\gamma U)$$
where U = M/r, and which can be regarded as the Newtonian potential energy. Also ##\delta_{ij} =## 1 if i=j and 0 otherwise
This is of course a lot of work. You'll most likely need to consult a textbook (such as MTW) along with a lot of time to go through it all.
But it is a textbook description of why we say that "spatial curvature" causes the doubling of the deflection of light. Implicit in talking about "spatial curvature" is a specific time slicing. The time slicing used in PPN and in the Schwarzschild metric are the same, they're the natural choice for the split which make the metric coordinate expressions time independent.
PeterDonis said:
...means there is room for a number of different viewpoints on what the [gauge] transformations "mean"
I'm not sure why you guys feel that the deflection of light is terribly relevant for this discussion ("cannot be ascribed to a force", connection of time dilation to forces etc.), but I have some remarks about this which may be relevant. The geodesic equation can also be written in the form
(d/ds) pi = 1/2 ∂gjk/∂xi pj pk
where vi = gijpj. Comparing the two equations
mai = -eFijk vi
d/ds ( gij vj) = 1/2 gkl,i vk vl
we see that there is the interesting fact that that the second equation not only has gradients of the potentials, but also the potentials themselves. This would be connected to the time dilation. Also the geodesic equation in this form is more obviously reparametrization invariant, and can be applied to light more easily. Also as I said, when I use the idea of forces, I am not saying curvature is irrelevant or wrong. This is partly just to get a handle on the confusion about which symbol is the gravitational field. The gravitational potentials are of course g_ij, which is clear from the fact that gravity is a spin-2 field. haushofer says F corresponds to something to do with the spin connection. There was a comment about the Weyl tensor as opposed to the Einstein tensor etc. But independent of all this, the 'force' concept seems to be the most unambiguous thing to define which won't be affected by the confusion of which symbol is what. Guage transformations have to do with transformation of the potentials, like A. and the closest thing to the potentials are the forces, which are the gradients of the potentials. So I feel we can talk about the potentials and forces without reference to the ill-understood 'analogy'
  • · Replies 0 ·
  • · Replies 37 ·
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 24 ·
