What is the purpose of the gradient vector in calculus?
The gradient vector in calculus serves two primary purposes: it indicates the direction of maximum change of a function and is normal to the equipotential surface at a given point. This duality can cause confusion, as the gradient is not necessarily tangent to the surface but rather perpendicular to it. To understand whether a surface is equipotential, one must consider the source of the potential field, such as gravitational or electric fields. Ultimately, the gradient provides the best linear approximation of change in the function near a point, reinforcing its role as a key concept in multivariable calculus.
kasse
What is the gradient vector, really? My textbook both states that it is a vector normal to a certain point on a surface, but also that it is a vector that points in the direction with the maximum slope of a surface. I find this slightly ambiguous.
It's confusing you because the gradient is normal to the equipotential surface. It does indeed point in the direction of maximum change in the potential, which is normal to the equipotential surface.
Think of skiing down the fall line of a slope -- you are following the gravitational gradient on the slope when you are following the fall line.
But how is it then that we get the normal vector if we compute the gradient at a certain point of a surface f(x,y,z)?
You will only get the gradient if the surface is an equipotential surface. Maybe I'm not understanding your question. Can you give a specific example of what is causing confusion?
Let's say we have the function f(x,y,z)=(2x-3y+5z)^5. If we want to find a plane tangent to the surface xyz=x^2-2y^2+z^3=14 at P(5,-2,3)
If we compute the gradient, we don't get a vector tangent to the surface, but normal to it. Is that because the surface is equipotential? Well, I don't know what that means. How can I know whether a surface is equipotential? :confused:
The gradient of a vector potential field is defined as being the normal to the equipotential surface at a point. The normal to a general surface is not necessarily the gradient.
To get an equipotential surface, you would need to know the source of the potential field (like gravity, or electric field, or magnetic field, etc.), and the shape of the geometry of any sources (like the earth, or coaxial capacitor plates, or an open coil, etc.). Given the source, you can calculate the field and the equipotential surfaces.
Actually, I misspoke there. The potential field is generally a scalar field, and to get the force field, you can use the gradient operator. Like in electrostatics problems,
E = - \nabla \phi
Where \phi is the scalar electric potential.
kasse:
Let us consider the equation:
f(x,y,z)=0
This equation determines a SURFACE, \vec{S}(u,v)=(x(u,v),y(u,v),z(u,v)), where u and v are variables parametrizing the surface.
In particular, this means that the two local TANGENT vectors to the surface are given by the vectors \frac{\partial\vec{S}}{\partial{u}},\frac{\partial\vec{S}}{\partial{v}}[/tex]<br /> <br /> Furthermore, for all (u,v), we have the folllowing IDENTITY:<br /> f(\vec{S}(u,v))=0<br /> Since it is an identity, we may, for example, diffferentiate with respect to u, yielding, with aid of the chain rule:<br /> \nabla{f}\cdot\frac{\partial\vec{S}}{\partial{u}}=0<br /> This tells us that the gradient of f is normal to a tangent vector to the surface; i.e, since this holds for the other tangent vector as well, we see that the gradient must be parallell to the surface normal.
Expand your function in a Taylor series at the given point. Then the gradient vector is the vector of coefficients of the linear term.
I.e. it is the vector such that the best linear approximation to the change in your function near that point is dotting with the gradient. Since the function does not change at all along the level surface, this gradient should dot to zero with the tangent vector to the level surface, i.e. it should be perpendicular to the level surface through the given point.
equivalently the gradient points in the direction of greatest change of the function near the given point, i.e,. as far away as possible from all directions tangent to the level surface.
e.g. the gradient of the function X^2 + Y^2 + Z^2 at (1,1,1) is perpendicular to the sphere of radius r = sqrt(3), i.e, it is parallel to the radius from (0,0,0) to (1,1,1).
(Does this seem right? I make a lot of mistakes in explicit examples.)
  • · Replies 20 ·
