The James Webb Space Telescope
545 replies · 69K views
Booster propellant loading should have started.
NASA coverage of the launch procedure has started, although it's just a video of the rocket for now.
Edit: Confirmation that propellant load is ongoing.
Reply
Astronomy news on Phys.org
DennisN said:
Thanks for the Christmas gift! :smile: I will watch this later today!
Happy JWST day! T minus 4 ish hours and counting and it's 8.48am here in this corner of excited sunny Manchester! (And merry Yule or something too)
Reply
Then refresh it. 20 minutes now.
185,000 viewers here:
10 minutes until the final weather briefing, 13 minutes until the rocket takes control of itself.
Reply
You beat me to it. :smile:
Reply
Final 7 minutes. Weather is good, the synchronized countdown sequence has begun where the rocket takes care of most of its operations. Fuel loading is almost complete, a little bit of venting can be seen.
Reply
Ok, time to wish the James Webb Space Telescope a safe flight and all the best!
Reply
Just needed to read further.
NOTE: speed and distance data becomes available on the Where Is Webb? page after upper stage separation. Temperature data becomes available 1-2 days after launch.
Second engine cutoff. Separation in about 2 minutes. Trajectory is still nominal: It will go to L2.
Edit: Separation. Ariane 5 did its job, JWST is on its own.
Reply
  • Love
Separated and leaving earth!
BEST CHRISTMAS PRESENT EVER!
😍:partytime:
Reply
  • Love
Merry Christmas!
Reply
What an amazing view from the onboard camera when the JWST separated!
I just sat and watched in awe.
Reply
Indeed!
Reply
  • Love
The next major event will be the first mid-course correction burn in about 12 hours. In one day it will deploy its high gain antenna.
Major unfolding will only start in three days.
The teams will run tons of tests now to verify everything is healthy.
Reply
Where is Webb page shows JWST beyond geosynchronous orbit and 2.5% of its journey to L2 complete! It's going to be a long 29 days but I have lots of hope for a successful mission!
Reply
155,000 km, 10.7% - but that's 10% of the distance not the time. The telescope is fast early on and slows down as its distance to Earth increases.
The first mid-course correction should happen within the next hour. Doing it early in the flight improves the efficiency - both from a smaller accumulated position error and from the Oberth effect.
Reply
Is it significant that the first mcc burn was substantially later than planned? Also any info on the planned delta V expectations vs reality?
Correct.
One quick note though, performing maneuvers early on are only more efficient via the Oberth effect if they are prograde (in the direction of motion) or retrograde (in the opposite direction of motion). More-so, JWST has severe limitations concerning retrograde maneuvers at this point in its trajectory. If it accidentally overshoots its prograde maneuvers, it could potentially doom itself to zipping past L2 with little or no way to recover.*
For directions orthogonal to the direction of motion (e.g., "normal," "anti-normal," "radial-in," "radial-out"), the Oberth effect actually hurts the efficiency, rather than helps. For maneuvers in these directions, it may be best to wait until the Earth's and Sun's gravitational tug slows it down a little. This competes with the idea that since a small change to an orbit now will have a large change to the orbital position later, that generally speaking, orbital adjustments should be done sooner rather than later. My point here is that the Oberth effect itself only helps the efficiency of prograde/retrograde maneuvers, and decreases the efficiencies of orthogonal maneuvers, in and of itself.
There's another mid-course correction scheduled in a couple of days (MCC1b).
*[Edit: And it is for this reason that Ariane-5's second stage intentionally cut short of placing the JWST directly on a path to L2. Overshooting L2 could doom the mission. So JWST will make up the difference during its mid-course correction burns (in addition to its final insertion burn), where the JWST thrusters have more fine control.]
We (i.e. I) find to easy to forget the relevance of some aspects of big projects. The L2 position is not stable so the situation is very different from setting a course for orbiting round a massive object. The inverse law for GPE of a target planet provides a certain amount of help for getting into orbit, once you are near. There is no such central force around L2 so I imagine everything needs much more precision and you have to make your own quasi orbit around L2 (to avoid being eclipsed by Earth). L4 and L5 would probably be less problematical in that respect. L4 and L5 probably have their own disadvantages. Those points are a long way away (many minutes of signal path delay) and a much longer journey time.
